Author Topic: project 71 cb750 with 330 wheel convertion  (Read 56121 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: my husbands project 71 cb750 with 330 wheel
« Reply #50 on: January 20, 2010, 11:47:19 AM »
I was going to reference your fork conversion thread as how it should be done. Guess I just did  ;D
http://forums.sohc4.net/index.php?topic=63784.msg696183
Good stuff
Did you cast that rake and lathe the handle yourself? Got pics? What sandpaper did you use?
I used a billet handle spun down on a JET 13" x 40" Belt Drive Bench Lathe, cut sheet metal for the tines,
and sanded with 320, 400, 600, 1500, and maas metal polish.  no pics, as the rake doesn't actually exist.
that link to the unknown members page should help him out at least with hanging it off the frame, his front end doesn't look finished yet either.
I couldn't find the link for that air setup, but I did find this overpriced junk-
http://www.tobefast.com/trickyair-busa-front-air-forks-pr-4469.html
the one I saw was different, it had modified fork caps that were basically just short fat cylinders and he removed the plastic spring spacer.
« Last Edit: January 20, 2010, 11:50:29 AM by Industrial Cafe »
Offline 333
  • Time for change
« Reply #51 on: January 20, 2010, 12:48:33 PM »
First post in this mess, but here goes.
The tensioner is on the wrong side.  The top. where the motor is pulling on the wheel sprocket is where the most tension is, and therefore needs no tensioner.  On the bottom, where there IS slack in the chain is where the tensioner is needed.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #52 on: January 20, 2010, 01:02:20 PM »
What he is doing is not so much of a tensioner, but rather to direct the chain over the top of the swing-arm.  If you look at his early pics, you can see how the alignment of the sprockets cause the chain to hit the swing-arm.  Also, I don't think there is any spring to his tensioner.  I do agree that a non-toothed whell would be better.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline 333
  • Time for change
« Reply #53 on: January 20, 2010, 01:10:50 PM »
But the mechanical advantage goes to the chain.  The way it is set up, the moment the chain tightens, that arm will twist on it's mounting point and allow the chain to hit.  Think of it this way.  Sure you can hold a 15lb bowling ball with one hand against your body, but try to hold it with your arm straight out to the side.  That sprocket needs a solid 90 degree bracket directly under the chain.
Offline kslrr
« Reply #54 on: January 20, 2010, 01:34:29 PM »
You are right about that.  I'm sure he'll figure it out since he is realy in a "try it and see what happens" mode.  Maybe he'll include a locking pin once the chain is where he want's it.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
  • Like a well oiled
    • Undead Asphalt
« Reply #55 on: January 20, 2010, 02:14:14 PM »
you may be correct 333, I think it's more animated than stationary, look at the hinged point... I think it moves :o
also, I'm worried about the jack shaft only having a strong fixed point on one side.
« Last Edit: January 20, 2010, 02:32:23 PM by Industrial Cafe »
Offline sangyo soichiro
  • Tuck
  • ☢ the atomic playboy ☠
« Reply #56 on: January 20, 2010, 02:24:11 PM »
This is a great point.  And as far as performance goes, a lot of the power coming from the drive sprocket is going to go to that little sprocket instead of the wheel where it ideally should go.
I've been distracted by the pissing match that I totally neglected the engineering of the bike.  Good thing folks like 333 are paying attention.
1974 CB 750
1971 CL 350 Scrambler
1966 Black Bomber
Too many others to name…
Offline bgfootball67
« Reply #57 on: January 20, 2010, 02:41:26 PM »
Correct me if I am wrong, but most of the slack in the chain will be eliminated when air is added to the rear shock and it is at ride heidth.  The other tensioner is used to help eliminate chain slap.  I have seen this set up on both the top and bottom of the swing arm on custom v-twins.  You can use a dirt bike set up to eliminate the slack, they work 100 times better than a skate board wheel (ask me how I know, different rubber compound)...
I asked quite a bit ago about him being worried about the power loss by running a jack shaft.  Every time I have seen someone use the jack shaft on a build they have plenty of horsepower to spare (Busa, big inch V-twin), he said he was not worried.
No disrespect Spanner & a few others, but if you made some of the comments on one of my threads like this one, I would have told you to go F yourself too.  JMHO....
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
  • Like a well oiled
    • Undead Asphalt
« Reply #58 on: January 20, 2010, 02:47:14 PM »
with a rake? :D :D
edit: I'd like to add, with all this jibber jabber I don't think the OP will ever find the real questions and concerns in the thread.
yes I am guilty of posting nonsense too.
« Last Edit: January 20, 2010, 02:50:07 PM by Industrial Cafe »
Offline mystic_1
  • 1970 CB750K
« Reply #59 on: January 20, 2010, 02:53:23 PM »
I mentioned the problem with the tensioner being up top, back on page.... er don't even remember now.
But trust me, the post exists ;)
So, 631, is the tensioner actually a tensioner or just an stationary idler?
mystic_1
- John Augustus Shedd
Offline Syscrush
  • Sold. :(
« Reply #60 on: January 20, 2010, 05:37:34 PM »
Wow.  What are the physics like in the world you inhabit?
  • Like a well oiled
    • Undead Asphalt
« Reply #61 on: January 20, 2010, 05:40:37 PM »
very physical.
Offline coldright
  • That's Ms.
  • to you
« Reply #62 on: January 20, 2010, 05:44:40 PM »
You're asking Soichiro this question?  Wow is right.
  • Tuck
« Reply #63 on: January 20, 2010, 06:43:00 PM »
Look at the photo.  There are three sprockets (EDIT:  Actually five sprockets... :)).  Ideally you'd want the chain straight on the top (consider the motion of the system).  The way it is now, the chain will exert a downward force on the center sprocket.  It's a wasted force that could have been applied to the rear wheel.  Plus frictional forces from that center doohickey...
So which part of what I said are you teasing me about; was it my use of the word "lot"?  Just curious.
« Last Edit: January 20, 2010, 06:51:11 PM by soichiro »
1974 CB 750
1966 Black Bomber
Offline Zaipai
    • My Home page
« Reply #64 on: January 20, 2010, 06:51:07 PM »
Look at the photo.  There are three sprockets.  Ideally you'd want the chain straight on the top (consider the motion of the system).  The way it is now, the chain will exert a downward force on the center sprocket.  It's a wasted force that could have been applied to the rear wheel.  Plus frictional forces from that center doohickey...
So is the bike lowed in this picture? And if it is would the chain not straighten up when it gets to riding height? Just wondering...
Its my Avatar..
75 CB550F  |
« Reply #65 on: January 20, 2010, 07:00:07 PM »
Well it's nice to see that the OP is back (and I'm sorry that his GF isn't coming back) and with the exception of Spanny, everyone's playing nice again.
There's nothing wrong with pointing out that one man's fabricating skills are rubbish, part of the problem with todays society is that a lot of folk think they're really good at something just because their family/friends don't want to hurt their feeling so they lie about how crap they really are, (take a look at the American Idol audition rejects, for example)  but I saw the nasty side of a few folks here who I thought were nice people, and that surprised me.
Anyway, welcome back mate, and I hope you make that thing work as good as it (almost) looks. No one here that I know of has achieved that huge tire look on a CB750, so if you make it work, you'll be up there with the great innovators on this site. You might even be able to do some "kits" for other like minded members, and make some bucks. Cheers, Terry. ;D
  • Tuck
« Reply #66 on: January 20, 2010, 07:03:44 PM »
It looks lowered judging by the looks of the "shock".  But then what happens when you hit a bump in the road and that little sprocket wants to stretch that chain...?  (Seriously.  Something's going to break.)
By the way, is that shock/suspension a pneumatic cylinder?  It looks like it.  How is that going to work?  Air is pretty "squishy," and the diameter looks fairly small.
« Last Edit: January 20, 2010, 07:07:36 PM by soichiro »
1974 CB 750
1966 Black Bomber
Offline 333
  • Time for change
« Reply #67 on: January 20, 2010, 07:07:10 PM »
Except that the jack shaft is at the pivot point of the entire swing arm.  So regardless of the angle of the swing arm, the chain won't tighten OR loosen.
Offline 333
  • Time for change
« Reply #68 on: January 20, 2010, 07:10:00 PM »
Don't ask.  It will involve a conveyor belt.
Offline edbikerii
    • Gallery
« Reply #69 on: January 20, 2010, 07:14:27 PM »
Forgive me if I'm wrong, but I don't think the builder's goal here is actually to get the maximum horsepower to the ground.
Frankly, I think "the look" of the fat-ass tire is the goal, no?
I mean, we all know that those fat-ass tires don't exactly improve handling, right?
Besides, what are we talking about on this bike, maybe 60 HP tops?
Not that that should stop any of the discussion here, as it is very interesting.
« Last Edit: January 20, 2010, 07:16:05 PM by edbikerii »
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
  • Like a well oiled
    • Undead Asphalt
« Reply #70 on: January 20, 2010, 07:15:40 PM »
exactly why I want him to post a video of it in action, even if it's lifted by a floor jack.
  • Tuck
« Reply #71 on: January 20, 2010, 07:17:14 PM »
Well, I'll admit that I'm having a hard time seeing exactly what's going on in these pictures.
1974 CB 750
1966 Black Bomber
  • Like a well oiled
    • Undead Asphalt
« Reply #72 on: January 20, 2010, 07:18:58 PM »
doesn't it look like the sprocket in the middle moves up and down opposite the suspension?
Offline 333
  • Time for change
« Reply #73 on: January 20, 2010, 07:21:59 PM »
Where do you see any lever or whatever that does that?  It doesn't even have a spring on it.
Offline edbikerii
    • Gallery
« Reply #74 on: January 20, 2010, 07:22:35 PM »
I thought it was spring loaded to serve as a tensioner.  ???
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
