Author Topic: CB550 K1 Do I need to torque all bolts when checking crank bearing clearances?  (Read 907 times)
Offline elquenada
My engine had 55,000 miles on the clock so while my 550 is apart I want to check out my crank bearing clearances using the plastigauge method.  The manual says to torque down the cases. Does that mean all 23 bottom case bolts plus the 6 up top?  Or do I just torque down the ones around the crank?
Also im wondering would it be advisable to reuse some bearing shells from my parts engine so long as they check out?
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline paddy paul
just torque the bolts for the crank,and if the bearings are within spec you can reuse them
Offline elquenada
ok thanks.
1975 CB 550
Lope de Vega
Offline Triffecpa
If you are going to reuse bearings, make sure that they get back onto the same crank journal if you pull them out of the cases.
Tracy
