Author Topic: looking for hi-perf cb450 parts  (Read 10185 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: January 05, 2010, 01:18:12 pm »
Hey guys-
I'm looking for some second-hand parts for a hi-perf cb450 engine, if any of you racing guys know anyone with a blown up engine or unused parts lying around.   ;D I have 12th over pistons already, and will port the head myself. I'm looking for cams, valve spring conversion, and rods primarily. Of course if there's a dry clutch conversion burning a hole on someone's shelf... ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Re: looking for hi-perf cb450 parts
« Reply #1 on: January 05, 2010, 05:07:47 pm »
It sure doesn't hurt to try, but ahh.... good luck with that Paul.  ;)
Offline paulages
  • 1976 cb735
« Reply #2 on: January 06, 2010, 12:48:42 am »
yeeeeeeeah, i know. it doesn't hurt to try.  ;) hell, someone has to have retired an engine here and there with good stuff in it, right?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline lordmoonpie
    • Moonpie
« Reply #3 on: January 06, 2010, 02:40:06 am »
Hey Paul - you can buy my tuned engine if you want, trouble is it comes with the rest of the bike attached LOL!  :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #4 on: January 06, 2010, 05:07:31 am »
Hey guys-
That valve spring conversion can be tricky Paul. There were problems with the inner valve spring rubbing on the guide seal and destroying it. Maybe Kibblewhite or Hanson could give you more on that.
Offline lordmoonpie
    • Moonpie
« Reply #5 on: January 06, 2010, 06:42:21 am »
That's the bit Mike's talking about that I mentioned Paul - there's barely enough meat in the head to convert them and if you're not used to doing them you can quickly end up with a big pile of scrap...
1994 Ducati 888 SP5
Offline paulages
  • 1976 cb735
« Reply #6 on: January 06, 2010, 09:28:56 am »
i keep hearing that the 500 head is "better," but i don't know why. i know you mentioned not knowing specifically simon, but i wonder if the 500 head has more material in this area making the conversion easier. i'll call kibblewhite, hanson, or one of the other guys offering it before i start, for sure. i noticed m3 offers the conversion kit with new valvesm ti retainers, etc.. maybe mark will notice this thread and pipe in.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline mlinder
  • "Kitten Puncher"
  • Moderator
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #7 on: January 06, 2010, 07:40:49 pm »
I think the 500 head was better because it had more material (as you said) which is easier to turn it into a downdraft setup.
No.
Offline turboguzzi
« Reply #8 on: January 07, 2010, 06:32:47 am »
there's still a very good article in motorcycle.com about the making of the henning CB's, worth reading
http://www.motorcycle.com/events/building-the-henning-honda-cb500-14621.html
http://www.motorcycle.com/how-to/modifications-to-the-henning-honda-cb500-14679.html
the winner of my class is CB450/500 twin based. supposedly the hot ticket is a 450 bottom end with a 500 head, the 450 head had a sort of iron skull if i recall right.
trouble is that to bring them to competitive HP you need to invest tons of money, or at least that's what i heard.
Capellini moto near milan is one big source of (expensive) parts. you have now a reason to come back for some more concerts....
http://www.cappellinimoto.it/
Offline kos
    • m3racing.com
« Reply #9 on: January 07, 2010, 08:27:49 am »
Hello
Mentioned on this thread is the fact that a CB450/500 is very expensive to make fast. Due to the  very 1960's cylinder head design you have to run a very high dome on piston to get compression, added to that one must deal with the very steep valve angle.  500 head is exactly the same in all respects as the 450 head, save for it has  ordinary valve seats vs the 450 which has a "skull" type iron/steel dome sunk into the head. 500 head is the best to use.
Right now would be the time to get yourself a CB350 Honda twin and go that way, as you will be spending 3X's money to get almost the same performance with 450/500 twin.
I did the work up with KPMI to make the 5mm valve spring conversion kit. Not anyone from Team Hansen had anything to do with that. Very nice kit, but not worth doing unless you remake (ie: machine cams for adjustable sprockets) both cams and go to 2 spark plugs per cylinder.
Next you will need to machine head for two spark plugs per cylinder to sped up flame path travel time for your ignition will per 45-50 BTDC!
Pistons larger than 72mm will need liners machined and installed as standard liners will distort and cause ring sealing problems.
You must move ignition from camshaft end to end of crank or your timing will vary enough, due to cam chain length/stretch enough to cause problems. This relocation makes the bike race-only...no street use, as you can run no AC generator.
A better oiling system is  also a good idea and out friend in Italy is the way to go in that department.
Also, if you are to run in top of class, must have Nova 5 speed (if you can find one) or newer 6 speed close ratio gear box.
I can build you a complete engine ready to run at front or could you consider another bike for this class? I also can supply all parts/services you will need for this effort.
KOS
http://www.m3racing.com
PS Our CR450 replica was 3rd at Daytona 1999, after leading the race and ended up just back of Franco Bonnera on Factory MV and Todd Henning on CB450.
1998 3rd overall in AHRMA National Championship
1999 2nd overall in AHRMA National Championship
220...221, whatever it takes.
Offline lordmoonpie
    • Moonpie
« Reply #10 on: January 07, 2010, 08:56:39 am »
+1 on the cost Mark is talking about for a top CB450 engine. Mine isn't as modified as it could be as I'm still on standard (NOS) rods but I'm into my engine for probably near £10,000. Is it worth it? Hell yes and with a lot of those hot parts already on sale at M3, it's just a case of saving those pennies  ;)
1994 Ducati 888 SP5
  • Moderator
« Reply #11 on: January 07, 2010, 09:14:50 am »
Have you ever thought of robbing a bank Simon ;D ;D ;D ;D
Sam. ;)
Offline paulages
  • 1976 cb735
« Reply #12 on: January 07, 2010, 09:16:54 am »
thanks, mark. hearing from you is worth a lot.
first i should mention that this will not be a race bike. i had originally intended it to be so, but decided the 350 sitting in the corner would be a much better candidate as you mentioned, not to mention the fact that i have my 550 race bike that needs attention before the coming season.
this project is just an excuse to use the tony foale motorcycle kinetics software i recently purchased and design a frame/suspension around an engine i have convenient to use. the 450 i have is a total rustbucket i got for free, perfect for the experiment. we will be fabricating the frame and swingarm, and using a modern front end with ohlins or comparable shocks. the bike will be more of a modern classic street bike type thing, but i'd eventually like to build a frame around something to race. the guy i'm building it with races in mini classes on a kx65 and an nsr65... i'm trying to get him out on the big track.
i picked up a +3mm piston kit with jugs already bored to spec locally for very cheap, and figure while i'm rebuilding the engine i might as well do whatever else i can (and can afford) while i'm in there. so ultimate performance for the track is not needed. i'd like to do what's sensible.
mark- really nice stuff on your site. can you sell me a couple wrist pin buttons? the kit i got came missing two..
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline kos
    • m3racing.com
« Reply #13 on: January 07, 2010, 12:00:02 pm »
Another way to do a CB450/500 is to leave most of it alone. This works well for hot street performance. While it will not light the world on fire...it does give this engine some get up and go without sacrificing reliability. Open up exhausts as much as you can stand the extra noise. Get some 32mm Mikuni's on it with air cleaners or stacks, depending on your riding conditions, then I have a great cam to use on intake side only (ex has too big of ports so stock cam works well on that side) and this cam works just fine with torsion bars. I also have a good electronic ignition to fit where OEM points were located.
Let me know if I can help.
M3
PS: Did you know that the 450 was to be a 350cc engine, until Bob Hansen of Honda told the Japanese that 'mericans' liked BIG engines! That is why it is not easy to make bigger without more massive amounts of $$$ being thrown at it. Also, CB350 is really a only 325cc engine...as it was to be a CB250..like over in UK and Canada. Hansen and sales staff at "merican Honda USA told the factory that bigger is always better over here.
Offline lordmoonpie
    • Moonpie
« Reply #14 on: January 07, 2010, 12:27:06 pm »
PS:  Hansen and sales staff at "merican Honda USA told the factory that bigger is always better over here.
Sam - whatever you do, don't tell the joke about the lunatic asylums.... ;)
1994 Ducati 888 SP5
Offline paulages
  • 1976 cb735
« Reply #15 on: January 07, 2010, 01:26:21 pm »
M3
Thank mark, I'm sure I'll need something from you before long. I have the mikunis already, as well as the big bore. The exhaust will be fully custom, so I can make it flow as well as I want. Seems like the intake cam is what I really need then.
I knew that the 250 and 350 share everything but sleeve/bore size, but I didn't know that about the 450. Interesting stuff. Gotta say though, they did a pretty damn good job on the 350 in terms of power and reliability.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Howell
  • Honda the power of dreams
    • CB500 classic racing
« Reply #16 on: January 09, 2010, 12:03:47 pm »
Here is my Cb450  which I raced in the ninetees.
I used Kawasaki GPZ1100 (aircooled) 74 mm Wiseco pistons and also the sleeves from that Kawasaki.
36 mm Dell Orto carbs, re grinded cams , ported head.
And double spark plugs , in the middle a 10mm sparkplug.
« Last Edit: January 09, 2010, 12:15:07 pm by Howell »
You meet the nicest people on a Honda
Offline paulages
  • 1976 cb735
« Reply #17 on: January 09, 2010, 12:34:13 pm »
beautiful!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Howell
« Reply #18 on: January 10, 2010, 03:04:37 am »
beautiful!
I have also tried a Femsa ignition, see the first picture.
It was a home build frame from reynolds 531 tubes , weight 9kg.
« Last Edit: January 10, 2010, 03:07:10 am by Howell »
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #19 on: January 10, 2010, 07:48:20 am »
i have a cb500t head if you need it
Mark Twain - Notebook, 1894
Offline paulages
  • 1976 cb735
« Reply #20 on: January 10, 2010, 12:34:27 pm »
perfect. PM sent.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
