Poll
What motion Pro cables do you have issues with?
CB550 Clutch
3 (15.8%)
CB550 Throttle (pull)
2 (10.5%)
CB750 Clutch
1 (5.3%)
CB750 Throttle (Pull)
3 (15.8%)
Other Clutch
1 (5.3%)
Other Throttle
2 (10.5%)
None?
7 (36.8%)
Total Members Voted: 15
Author Topic: What motion Pro cables do you have issues with?  (Read 1794 times)
Offline Flying J
« on: January 07, 2010, 11:43:45 AM »
« Last Edit: January 07, 2010, 11:47:48 AM by ffjmoore »
Offline Gordon
  • 750K1, 550K2
Re: What motion Pro cables do you have issues with?
« Reply #1 on: January 07, 2010, 11:47:17 AM »
There's no "None" option
Thanks! :)
« Last Edit: January 07, 2010, 11:55:04 AM by Gordon »
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: January 07, 2010, 01:08:31 PM »
You can now vote for as many options as you like.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Flying J
« Reply #3 on: January 08, 2010, 09:14:38 AM »
ANybody else?
Offline JBMorse
    • Travel Blog
« Reply #4 on: January 08, 2010, 04:39:39 PM »
For my CB500, I have a Motion Pro tach cable and both throttle cables, and they fit fine.  Same length as the originals.  I did buy a Parts Unlimited clutch cable, though, which was overall a little longer than the stock cable.  Not by much, maybe 1" or a little more.  The total throw length of the cable was the same, so the cable worked fine.  I didn't like the quality of the end as much as the stock or the motion pro cables though, I can't remember exactly why.  I think the solid metal cylinder, the cable end itself, was a little smaller than the original.
Hope that helps.
1971 CB500K
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #5 on: January 08, 2010, 07:13:01 PM »
There is no selection for pro-motion tach cable.
Mine falls apart....
On my CL360 the Tach cable is too long and rubs all over including the tire..
« Last Edit: January 08, 2010, 07:15:02 PM by Simpson »
1970 CB750 K0
1975 CL/CB 360 Mix
Offline leekellerking
« Reply #6 on: January 08, 2010, 07:46:16 PM »
My new Motion Clutch cable for my 1982 CB650SC appears to be longer than stock and I didn't realize it was hitting an exhaust pipe until it melted through the plastic.  I wrapped it in tape after wiring it out of the way, and it works fine.
Still a bit too long, but I can live with it.
Lee
My Nighthawk is put together with wire and zip ties, burns oil, and handles like a pig.  I love it!
