Author Topic: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)  (Read 142414 times)
Offline greasy j
  • lanesplitting
  • non serviam
Re: CB750 Dual disc front end swap (with GSXR1000/600/750 parts)
« Reply #325 on: June 04, 2010, 10:58:35 PM »
your bike is looking great! nice work.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #326 on: June 05, 2010, 07:52:38 AM »
thanks,
right now I'm thinking about getting a different tank, my forks hit this one and I've scooted it back as far as I can...
maybe a Gus Kuhn tank
 or a gs450/gsx250/gsx400 tank.
the early 80s suzi's had a very pointy tank that would stop my lock to lock issue.
$150 plus $110 -S/H  ...from Singapore.
I think I can get it cheaper from a more local source though.
« Reply #327 on: June 05, 2010, 09:34:35 AM »
if i were in your shoes
if your planning on replacing the tank anyway,  you should try forming the fiberglass, like you did to the headlight ... if you #$%* it up , you were gonna replace it anyway .
   edit: now that i think about it , not sure that would work ... but .. i'm not sure that it wouldn't either
Offline greasy j
  • lanesplitting
  • non serviam
« Reply #328 on: June 05, 2010, 10:11:50 AM »
how long is that suzuki tank?
  • Like a well oiled
    • Undead Asphalt
« Reply #329 on: June 05, 2010, 12:59:57 PM »
about an inch or so shorter than my dunstall tank.
it's about this long
click below
member: Bigsherm
« Reply #330 on: June 05, 2010, 01:05:48 PM »
i'm in ...looks awesome .. make it happen
Offline Flying J
« Reply #331 on: June 05, 2010, 03:35:31 PM »
That dunstal just doesnt look right on your bike. I wonder what it would look like on mine?? ;) Send it on over so we can find out.
  • Like a well oiled
    • Undead Asphalt
« Reply #332 on: June 06, 2010, 06:41:11 AM »
heh yeah,
         it needs a seal job and some large-ish repairs on the petcock area... not to mention there's a zombie girl engraved into the top.
I was gonna use it on an SOHC4 cafe four wheeler project I want to do.
  • Like a well oiled
    • Undead Asphalt
« Reply #333 on: July 10, 2010, 06:29:00 PM »
I left the grips in the tan dye too long, they were white...
     I've already bleached them twice, they were greenish black. maybe they'll fade out in the sun.
  • Like a well oiled
    • Undead Asphalt
« Reply #334 on: July 10, 2010, 06:32:10 PM »
I may just get some more white grips and dye them again one day.
Offline Zaipai
    • My Home page
« Reply #335 on: July 11, 2010, 06:44:57 AM »
I like it they match the seat and are much better then the ones you had. I like the seat also. You made that one correct? Good work.
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline Freaky1
« Reply #336 on: July 27, 2010, 06:59:09 AM »
Wow, I've been seeing a '77 F in the neighborhood that has no front end and thinking I know I could find the parts to make it stock but then the fabricator inside just starts screaming "This is a gift, make it something shocking!". Well thanks to IC and a few others here the seed has been planted. I have always had a thing for the inverted forks and now I know I can make it happen.
That is some great work and a great thread about it also, I am set to be notified. I'm not sure what to do about the wheels though because I want to stick with rear disks but all in due time.
I'm interested to see how the gauges turn out.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
  • Like a well oiled
    • Undead Asphalt
« Reply #337 on: July 27, 2010, 12:36:44 PM »
you could always make rotor spacers/adapters for the stock F wheel.
 that's what FunJimmy did.
Offline Freaky1
« Reply #338 on: July 27, 2010, 01:37:46 PM »
I have not had time to check out his entire thread, but I will! My project is still in the planning stages and I've got all winter to make it happen.
I love this forum!
  • Like a well oiled
    • Undead Asphalt
« Reply #339 on: July 27, 2010, 04:02:28 PM »
I think it's the greatest forum on the web...
Offline MattFreeman
  • What Have I Done?
« Reply #340 on: August 08, 2010, 02:54:17 PM »
To take a step back a couple pages. How awful would it be to just skip the front fender all together?
On another note I picked up a 91 gsxr fork and clipons with a lever/mc, caliper and rotor from a 98? 'busa for $240. I cleaned up the lower tree and had it powdercoated with black wrinkle. I am having a friend make a plug insert to stretch the steer tube to length as we speak and soon it will be ready for a wheel. Thanks for the inspiration.
Anyways I am considering running w/o a fender, I like the look.
  • Like a well oiled
    • Undead Asphalt
« Reply #341 on: August 08, 2010, 06:10:59 PM »
you can run without a fender if you want to.
   for me I don't like getting hit in the face with fine gravel at around 35mph or messing up my engines paint job.
Offline 77cafe750
« Reply #342 on: August 08, 2010, 10:28:52 PM »
gravel in face sounds like fun lol and if you decide to get rid of that tank uhmm let me know lol
live like an outlaw and love like an angel
crash
blacked out gauges rock
http://forums.sohc4.net/index.php?topic=67710.0
  • Like a well oiled
    • Undead Asphalt
« Reply #343 on: August 08, 2010, 10:50:31 PM »
werd.
Offline MattFreeman
  • What Have I Done?
« Reply #344 on: August 09, 2010, 05:53:14 AM »
Squirley's bike skipped the fender, so I must not be that crazy. Or not the only one. I guess I'll keep my visor down.
  • Like a well oiled
    • Undead Asphalt
« Reply #345 on: August 09, 2010, 08:34:30 AM »
his bike is radder than mine, it can rock the "no fender" look, no problem.
« Reply #346 on: August 09, 2010, 04:17:33 PM »
If you are interested in having your front end handle well then the front guard has a fork brace built in, not only will it flex and twist more without it, you will NEVER ride it in the rain or on any dirt, it also trashes {sandblasts} your engine.
  • Like a well oiled
    • Undead Asphalt
« Reply #347 on: August 09, 2010, 04:41:38 PM »
my fork tubes don't have a brace built into the factory fender...
   I'm not sure if it's necessary when the tubes as thick as they are
EDIT: I had some minor twist in the forks until I tightened the 4 bolts at the axle, maybe that's what they did for strength?
« Reply #348 on: August 09, 2010, 04:56:41 PM »
It seems that upside down forked bikes have no fork braces, they are supposed to be a lot stronger than conventional forks. I was just reading that in extreme circumstances, upside down forks only fault is twist...and apparently this only happens on certain bikes...
  • Like a well oiled
    • Undead Asphalt
« Reply #349 on: August 09, 2010, 05:00:05 PM »
ah, I see.
