The SOHC/4 World Tour is in under way.
now for the stem problem, the suzuki stem is about a 1/2 inch too short so I cut it off and pressed in a 76 CB750 stem. (my 71 was a smaller diameter inside the tree casting and damaged as well)had to heat it up and stretch it 1 mm to fit into the GSXR treepressed it in and here it isfrom left to right- cut piece of gsxr stem tool to stretch the 750 stem tool to press it out and the done deal fits perfectly now.mock up so far.
mega thread necromancy: i've got parts coming for this swap, and i'm starting to prepare but had a quick question. what did you cut your stem out with? i cant get a good line on it and worry about nicking up the the stem.
got it. ive got a line on a 20 ton H press that i was planning to press out the gsxr, makes sense that i can press out the cb750 too. thx for the smack to the head guys, haha.
Quote from: diminished on September 22, 2011, 11:54:50 AMgot it. ive got a line on a 20 ton H press that i was planning to press out the gsxr, makes sense that i can press out the cb750 too. thx for the smack to the head guys, haha.it's not as easy as you think though. it doesn't press out like you'd expect.if you notice, op probably used a hacksaw or cutting wheel to remove his.
...Industrial Cafe hasn't been around here for a while now.....
Quote from: Retro Rocket on September 20, 2011, 10:12:34 PM...Industrial Cafe hasn't been around here for a while now.....What up? Is he OK? I hope I have not missed anything...
