Author Topic: Considering a CT90. How does the clutch work?  (Read 3752 times)
Offline fmctm1sw
« on: January 08, 2010, 03:30:01 PM »
Got offered an old CT90 for $75.  If I recall it had clutch issues and maybe compression issues too.  One thing I am curious about is how the automatic clutch works in those.  I saw a photo of somone with one of them apart and I expected to see a lot of trickery and complicatedness in there.  All I really saw was clutch plates though.  It can't be that easy, does anyone have a good link to a explanation of how that works?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Old Scrambler
Re: Considering a CT90. How does the clutch work?
« Reply #1 on: January 10, 2010, 12:36:30 PM »
Go to the VJMC site or any HONDA dealer.  It is a centrifugal clutch. When the motor is at idle, no pressure on the clutch so it slips. At higher RPMs the throw-weight puts pressure on the plates to lock them up.  When you shift gears it is best to relax the throttle for an instant while you work the shifter. All up....then all down to neutral.  Low compression is common on small singles that have been sitting or are worn.  New rings and a valve grind will get you going. If you have a very badly worn cylinder, you can purchase the 110 kit that was a stock production in later years.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: January 10, 2010, 02:03:50 PM »
ah, so like a go-kart then?
Mark Twain - Notebook, 1894
« Reply #3 on: January 10, 2010, 02:27:39 PM »
Not exactly. On a go kart (at least the one I had) the throw weights double as the friction. On the CT90 (whch I had one with a Powroll 110cc kit) the clutch friction part looks like a conventional clutch. IIRC  The throw weights don;t double as part of the friction drive mechanism.
Also, on the CT90 part of the throw of the shifter does duty as a "clutch lifter" like pulling in the lever/ cable. Again, IIRC.
The CT90 is not so much an automatic as it is a clutch lever-less transmission. YOu still have to push a shift pedal and things are still happening like a conventional system, with a minimum of exceptions.
An example, if you depressed the shift pedal all the way, you could rev it to the redline. Then allow the shift pedal to return to its relaxed position. THis would engage the clutch a pop a wheelie.
« Last Edit: January 10, 2010, 02:33:35 PM by MCRider »
