Author Topic: Big Bang camshaft configuration  (Read 5244 times)
Offline mystic_1
  • 1970 CB750K
« on: January 11, 2010, 12:45:56 pm »
Over on Hondachopper.com there's a thread discussing the "Big Bang" firing order, apparently this involves a replacement cam and timing gear to fire 1+4 as a pair and 2+3 as a pair.  Seems this has some advantages in controlling/recovering from wheel slip in corners during racing.  Anyone have any experience with this?  I'd never heard of this particular mod before.
http://www.hondachopper.yuku.com/topic/27605
Some relevant info I found via Google:
http://en.wikipedia.org/wiki/Big-bang_firing_order
http://www.perthstreetbikes.com/forum/f16/making-big-bang-engine-77160/
http://www.crash.net/british+superbikes/feature/3632/1/exclusive_virgin_big-bang_secrets_revealed.html
mystic_1
- John Augustus Shedd
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Big Bang camshaft configuration
« Reply #1 on: January 11, 2010, 12:52:44 pm »
It's also great for major wear and tear on the engine, with frequent rebuilds, from what I've heard. :)
No.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: January 11, 2010, 01:51:10 pm »
I think it's mainly for dirt/hill climb.  Massive low-end torque, not much on the top end.  Instead of Bang-Bang-Bang-Bang, you get BANG-BANG-rest-rest.  The rest-rest phase is the re-grip which works kinda sorta like anti-lock brakes.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Tnutz
« Reply #3 on: January 11, 2010, 03:32:02 pm »
sounds like one giant paralell twin in that configuration
2004 Ducati 999 mono posto.
-Full Termignoni exhaust
-Lots 'o' carbon fibre
1973 Honda cb500/4
-Motor Rebuild
-Has clubmans
-Paint is sub par
Offline Syscrush
  • Sold. :(
« Reply #4 on: January 11, 2010, 04:51:52 pm »
Big Bang is so 20 years ago!
Crossplane's where it's at, dude. ;D
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: January 11, 2010, 06:05:26 pm »
I bet it makes one hell of a sound, and therefore the "Big Bang" moniker :)  I can also see how this configuration would wreak havoc on all the internal parts in a very short time.  The staggered impulses and increased torque must be hell on the primary chains.
Syscrush, "crossplane" eh?  Anyone ever done that with a Honda SOHC that you know of?
I'm continually amazed at the things people do to these bikes.
mystic_1
Offline IHWillys
« Reply #6 on: January 11, 2010, 07:20:36 pm »
I think it's Yamaha only at this point, as far as inline fours go.
Ken
« Last Edit: January 11, 2010, 07:29:45 pm by IHWillys »
Offline Syscrush
  • Sold. :(
« Reply #7 on: January 11, 2010, 07:29:24 pm »
It would require more than a cam & ignition change - it would require a custom crank, and ideally a balance shaft, too.  I've never heard of anyone changing a production screamer or big bang I4 to a crossplane.
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: January 11, 2010, 07:51:35 pm »
One of the guys over at Hondachopper.com had this to say re: the Big Bang setup:
Neal is right, there were some called a Big Bang Cam. Mine was called Twin Fire, and was labelled APE. APE is still in business, and might be able to give you more info on it.
I sent a PM to Big Jay, maybe he'll have some comments.
mystic_1
Offline Big Jay
    • CBRzone
« Reply #9 on: January 11, 2010, 08:45:33 pm »
We only made one of those cams. It fired two cylinders at a time, not a cross plane like the 09 Yamaha.
We gad to move some cam lobes around on the cam. We did it for a drag racer. He stated that the motor ran as planned, but was no faster than a conventional firing engine.
Offline mystic_1
  • 1970 CB750K
« Reply #10 on: January 11, 2010, 10:18:22 pm »
Well you must have done a great job on it then, seems it's still out there in a running bike :D
I did put it in a motor, and did notice differences! It sounded like a bumble bee, a big one! Best guess would be a big cb350 twin, and a noticeable lower end grunt! That is all i can remember about it!
http://www.hondachopper.yuku.com/topic/27605?page=1
mystic_1
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #11 on: January 11, 2010, 11:53:22 pm »
would not require a new crank. 1-4, and 2-3 already rise and fall together. it essentially makes it a 360 degree "twin," like most british twins of the 60's and '70's.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #12 on: January 12, 2010, 01:19:20 am »
Dammit, now I want a big bang cam! ;D
Offline turboguzzi
« Reply #13 on: January 12, 2010, 01:47:11 am »
nothing wrong with trying that but essentially you will be multiplying loads on all transmission gears/chains X2.
with stock firing order, torque load at any given time equals the force of only one cyl, with a big bang I-4 you will get two bigger torque peaks rather than four per engine cycle.
the yamaha crossplane is not a real big bang, the idea there is to keep crank speed more stable to improve drive control. By the way, Helmuth Fath tried it way before yamaha in the 60's in his 500cc GP sidecar motors.
Offline lordmoonpie
    • Moonpie
« Reply #14 on: January 12, 2010, 03:55:43 am »
I had a crossplane crank in my TVR sportscar too! (way before I got married  ???)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #15 on: January 12, 2010, 04:58:59 am »
I know a hill climber who used that setup in his CB750 powered unit. He has a lot of trophies.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #16 on: January 12, 2010, 07:41:50 am »
He's talking about crossplane, not big bang, Paul. Crossplane would require a new crank and cam.
No.
« Reply #17 on: January 12, 2010, 08:03:38 am »
And ignition ECM ;)
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #18 on: January 12, 2010, 08:09:40 am »
That too :)
No.
« Reply #19 on: January 12, 2010, 08:28:32 am »
I'm sure it could be done with points Mark....my mistake. ;) ;D
« Reply #20 on: January 12, 2010, 09:01:59 am »
Nearly right Paul, it wouldn't need a new crank but it would be like a big 180 degree twin like the CR93 and CB72/77s.
The 360 British twins are like the CB92 and C72/77s, both pistons rising together but one firing while the other is exhausting.
Sam. ;)
« Last Edit: January 12, 2010, 11:38:02 pm by SamCB750A »
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #21 on: January 12, 2010, 09:02:34 am »
That sounds messy....
No.
Offline paulages
  • 1976 cb735
« Reply #22 on: January 12, 2010, 09:25:22 am »
The 380 British twins are like the CB92 and C72/77s, both pistons rising together but one firing while the other is exhausting.
Sam. ;)
yeah, you're right.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline mec
« Reply #23 on: January 14, 2010, 07:11:03 am »
the big bang firing order is not worth a thought on our weak vintage bikes.
big bang or screamer, it seems it is more a yearly trend made by commercial experts.
big bang is a must have, it does good to the rear tire and is better controllable out of corners.
screamer is the way to go, gives more power and is controllable as well.
big bang .......the way to go.
the motoGP ducati with 1000ccm was a big bang.
the GP09 ducati was a screamer.
the GP10 will be a big bang
what more to say.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
