Author Topic: HELP!! I installed a new clutch and now it slips reallly bad!! What did I do??  (Read 2177 times)
Offline CB750R
  • 77 CB750F
How do I fix the mess I have created?? I've adjusted everything I can, I've had the Clutch in and out 3 times now!?!?!?! I had to walk away or I was going to start throwing tools!!!
Any suggestions that are a bit more productive?
scottgarland
Did you use a shop manual for instructions? Check to see if frictions plates and clutch plates are in correct order. Usually things like this are because of a small oversight. Relax go back to the bike after you take a breake, then reread the book, you will probably find the answer once your not stressed out  Scott in San Diego
BarryKelly
Some oils contain friction reducing additives, which can cause the clutch to slip.  In your rebuild of the clutch did you use any of these?
Barry
