Author Topic: Quick Carb Tip  (Read 749 times)
someguy
Quick Carb Tip
« on: January 14, 2010, 04:37:17 AM »
You'll have to forgive me if this tip is obvious to everyone but me - I thought it was useful. While putting together the carbs from my 1978 CB550K last night, I kept wondering if the fuel flow valves were seating correctly or whether they were leaking. It occurred to me that there was a simple way to test:
Tilt the carb so that the floats close the valves, and blow into the fuel line (I had just replaced this line, so no cancer for me, I hope). Its easy to tell if you have a leak: you will be able to blow air through. Then tip the carb so the floats open the valves - you should feel no resistance blowing through.
Turns out my valves were sealing very well. Yay!
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Quick Carb Tip
« Reply #1 on: January 14, 2010, 08:46:02 AM »
That's actually a great idea. Been having problems with my #2 carb overflowing and this is a good way to see if it's the float valve. Thanks for the tip!
