Author Topic: Removing stuck tappet covers - help!  (Read 3158 times)
Offline Magpie
« on: January 14, 2010, 05:30:37 PM »
I've managed to loosen 4 of the 8 tappet covers but the last 4 - no way so far. The po used some sort of sealant and of course I've managed to pretty much round off the 17mm head on them. I sprayed some penetrating oil called Creep on the inside and letting it soak for a bit. I heated it as well before doing this. Any hints to get these 4 buggers please and thanks!
Cliff.
Offline Simpson
  • I ain't no
  • Aged to perfection
Re: Removing stuck tappet covers - help!
« Reply #1 on: January 14, 2010, 05:42:32 PM »
Here's what I would do... Of course I'm sure others will have much better suggestions.
Keeping in mind you need all new replacement tappet covers:
1.) Remove valve cover from engine
2.) Heat tappet cover slighly
3.) Tap carefully with rubber mallet or hammer to shock sealant
4.) Latch on aggressively with vice and turn
1970 CB750 K0
1975 CL/CB 360 Mix
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« Reply #2 on: January 14, 2010, 06:03:10 PM »
I hammered a the next size smaller socket onto the rounded cover, then I used a 20 inch pipe for leverage.
Offline Magpie
« Reply #3 on: January 14, 2010, 06:41:46 PM »
THANKS Simpson! The vice worked and only 1 small mark in the covernbear #4 exhaust. This place is such an incredible resource centre!  ;D
robdrobd, thank you too. I'll keep that in mind for next time if there is one. Good thing I have a spare set of covers.
Cliff.
Offline fmctm1sw
« Reply #4 on: January 14, 2010, 06:50:57 PM »
I've grabbed at them with vice grips...  Some you can only get like that with the valve cover off though IIRC...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Simpson
  • I ain't no
« Reply #5 on: January 14, 2010, 10:07:28 PM »
Woohoo! The project moves forward.  ;D
1970 CB750 K0
1975 CL/CB 360 Mix
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: January 15, 2010, 05:16:16 AM »
Know you got them off already, but for the future and for others if you have to go at them with vise grips, clamp onto the outside diameter of the covers rather than the hex, that'll give you more leverage.
mystic_1
- John Augustus Shedd
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #7 on: January 15, 2010, 05:27:09 AM »
i have some spare tappet covers if you need em. they need to be cleaned up and polished (they were on a motor that was stored outdoors before i got it)
Mark Twain - Notebook, 1894
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #8 on: January 15, 2010, 06:10:21 AM »
You would have chewed em up pretty bad, but a pipe wrench will never fail!
I had a stuck filler bolt on my tranny in my jeep and after about an hour of effing around with it, a little light bulb came on and I picked up a pipe wrench. Tightened it back up with it too, so I'm going to be the a$$hole PO when the next owner tries to change the fluid!
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline Magpie
« Reply #9 on: January 15, 2010, 07:36:41 AM »
mystic_1, that's how I got the last one off. Unbelievable how tight they were. It's a good reminder just to snug them up when putting them on.
bucky katt, thanks for the offer. I have a number of spares but will keep you in mind.
Cliff.
Offline mick7504
« Reply #10 on: January 15, 2010, 07:52:55 AM »
A smear of silicon grease on the o rings helps too and as mystic_1 mentioned, just nip/snug 'em up.
I don't recall ever seeing an oil leak there.
If I was you
I'd be worried about me.
