Author Topic: About welding aluminum  (Read 1729 times)
Offline Gnat
« on: January 15, 2010, 07:35:18 AM »
While cleaning 20 years of grit and grime off the oil pan I noticed this crack. Is this reasonably fixable. Also can the outside be built up so it can be filed and polished back. I know it can be done on steel but what about Aluminum
TIA
Gnat
"Trying to keep the rubber side down"
Offline mick7504
Re: About welding aluminum
« Reply #1 on: January 15, 2010, 08:02:52 AM »
Mate it's quite fixable.
Aluminium can be welded.
Is that a rocker cover off a 750?
It's a bit hard to tell from the pics but that's what I'm guessing.
If it is, then it is probably worth considering getting a second hand cover and using it rather than spending the time and money repairing the one you have.
If I was you
I'd be worried about me.
« Reply #2 on: January 15, 2010, 08:04:51 AM »
X2
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #3 on: January 15, 2010, 08:09:17 AM »
i'd try Alumiweld   http://www.alumiweld.com/
Mark Twain - Notebook, 1894
Offline Gnat
« Reply #4 on: January 15, 2010, 08:14:04 AM »
No..its the oil pan/sump errrr don't know what else to call it. Goes on the bottom of the engine ;D
« Reply #5 on: January 15, 2010, 08:25:56 AM »
To fix the cracks and prevent leaks you would use the aluminum welding inside the sump. For cosmetics you you could us e the rods or JB Weld and paint on the outside. You can get the rods at Home Depot. You will need something hotter than a propane torch.
Offline Gnat
« Reply #6 on: January 15, 2010, 09:04:50 AM »
Would a MAPP gas torch do the job?
Gnat
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #7 on: January 15, 2010, 09:32:59 AM »
DANG! That's some neat stuff. Wish I knew about that last week. Too late now...
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #8 on: January 15, 2010, 10:27:10 AM »
Gnat
Mapp is what you would use. You can get the rods ar Home Depot or Lowes. Bernz o Matic packages them.
Offline Nikkisixx
« Reply #9 on: January 15, 2010, 11:18:53 AM »
X2!  To me mig or tig welding any part that has been soaked in oil is a PIA because it is hard to get the oil out of all the nooks and crannys.  I'll have to break something so I can give this stuff a try.
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #10 on: January 15, 2010, 11:33:38 AM »
Those alumiweld rods are great for light or cosmetic repairs,
but don't use them on any stressed parts. It's just not made
for that.
FYI - they are great to "fill and drill" stripped out bolt holes.
I've done that and it works great!
Bikes parked out front mean good chicken-fried steak inside.
Offline Jim F
  • go baby go
« Reply #11 on: January 15, 2010, 11:45:01 AM »
I could laser weld it first to blow out the impurities then tig it if you want to give it a try. My web page is www. Jmfmicroweld.com
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline mystic_1
  • 1970 CB750K
« Reply #12 on: January 15, 2010, 02:30:03 PM »
Here's some info on that Alumiweld for y'all:
http://forums.sohc4.net/index.php?topic=36600.0
mystic_1
- John Augustus Shedd
« Reply #13 on: January 15, 2010, 02:44:43 PM »
What part of the world are you in and what bike? It doesn't look like a 750, if it was, I'd give you a good sump. There might be a member nearby who could help. I'm taking my tig to Davenport Ia. to weld on a funny car for a friend tomorrow.
Offline Gnat
« Reply #14 on: January 15, 2010, 03:53:13 PM »
Mr French e-mail sent.
I am in Olive Branch MS a suburb of Memphis Tennessee
Gnat
Offline Alan F.
« Reply #15 on: January 15, 2010, 06:28:24 PM »
If you guys like alumiweld, try HTS-2000 www.aluminumrepair.com I've been using this stuff for fabrication projects for quite a while.
-A
