Author Topic: Ever have to redo something after you think you're done?  (Read 2543 times)
Offline Magpie
« on: January 18, 2010, 08:20:07 AM »
Dammit? Why do I do this? ??? Is it just me? ???
I've reassembled my motor with lots of notes and pictures and after reviewing the pictures realize while I was careful to make sure the two O rings, or packings as the parts book calls them, on top of the cylinders were 16 mm, I forgot to double check to be sure the ones that go on the upper engine case were right!!! This is for a 750K0 motor. When I measured the top ones I had put ones in about 15.7 mm and saw they didn't fill the space for them so changed them to 16mm. As you can see in the picture the lower ones look "loose". The oil for the head pass through these areas and I don't want to compromise the oil flow. Dammit. So the engine comes apart again.
Sorry, had to rant! Thanks for listening but don't tell anyone please.
"Do it again" Cliff.
Markcb750
Re: Ever have to redo something after you think you're done?
« Reply #1 on: January 18, 2010, 08:25:32 AM »
Hire employees to do it for you, you will be amazed how many times it takes three or four attempts for them to remember how to do a job they claim to have been doing for 20 years.
Or it could be early onset dementia, yours or mine?...  It doesn't matter.
« Last Edit: January 18, 2010, 08:48:01 AM by Markcb750 »
Offline Magpie
« Reply #2 on: January 18, 2010, 08:35:43 AM »
Hi Mark! I'm sure it has something to do with my dementia. Good post on the screwdrivers! No one around here has heard of JIS so I'll look out for the Crescent one.
Cliff.
Offline myhondas
  • Not really such a
« Reply #3 on: January 18, 2010, 10:04:49 AM »
Yea, but whats even worse is when you get it all back together and you find you still have some parts left ;D and no idea where they go. ??? ::) :o
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline Magpie
« Reply #4 on: January 18, 2010, 10:12:07 AM »
Or find a little tiny o ring on the floor below the workbench - is it the old one? ??? ::)
Cliff.
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #5 on: January 18, 2010, 10:18:46 AM »
Seems like everything I do on my bike I have to redo!  ;D But that should make it twice as good as before, right?
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
« Reply #6 on: January 18, 2010, 10:36:15 AM »
Hi,
 I am at the same stage of assembly on my sandcast. Thanks for the reminder. Looks like a good opportunity to install heavy duty studs.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
Offline Old Scrambler
« Reply #7 on: January 18, 2010, 11:08:14 AM »
In 1971 I replaced a bent frame on a CL350. It was my first attempt at bike building and everything was perfect! I have not had that good fortune since. Am now replacing a camchain link after running with a lowd tick-tick-tick because I did not check for clearance for the heavy-duty unit. Of course the motor has already been out of the repainted frame one extra time because the guys I hired to rebuild the motor with new pistons put the cam in at a quarter turn wrong. Nice back-pressure through the carbs!
Oh Yeah.......and last year it was the 12-over big piston kit replacement in a 305 scrambler. Everything was fine until the motor was fully assembled. Apparently the head gasket squeezed into the chamber because I could FEEL something when I cranked the motor by hand on my bench. So out it came and a smaller kit with barrels was found in my stash. Anybody got a super-sized head-gasket for a 305 twin?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Magpie
« Reply #8 on: January 18, 2010, 11:36:03 AM »
Well, at least I don't feel so lonely now. Thanks guys! ;D
Cliff.
Offline Toxic
« Reply #9 on: January 18, 2010, 11:43:50 AM »
Well, if we were all honest, I'm sure most of us have done it.
A motor re-do is at the extreme end of the sepctrum. bummer
It can be the little things like did I leave out one ball bearing from the steering stem.
I've redone my electrical panel 3 times because I keep thinking of a better way to do it.
Tail light 4 times.
Sometimes I gotta know when to leave it alone and walk away.
I feel you pain
DaveNTexas
« Reply #10 on: January 18, 2010, 03:13:41 PM »
If perfection is the goal, of course it will never really be 'done'!
Offline Steve_K
« Reply #11 on: January 18, 2010, 03:35:30 PM »
When something does not work the way I expect and I have to redo it I say,  "That was the prototype and I needed to check the design!" Sometimes people will believe it!
Steve
Steve_K
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #12 on: January 18, 2010, 03:42:31 PM »
I'll be taking my front brakes aparts again this week for the third time. The brake light pressure switch keeps leaking brake fluid. Nothing like bleeding your brakes over and over. Such a fun process. Your not alone!
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
« Reply #13 on: January 18, 2010, 04:04:27 PM »
I redid many things on this bike including motor, top end, bottom end, carbs, cabling.  I'm not stone confident on everything except tranny as I'm about to re-embark on doing that one.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Offline bubbafun101
    • My K3
« Reply #14 on: January 18, 2010, 04:15:01 PM »
I have had that problem every time I work on my carbs. Not in 10 yrs have I had a "once and done" with my carbs. Sometimes you just wanna yell!!!
CB750Winger
« Reply #15 on: January 18, 2010, 04:53:41 PM »
  Don't feel bad, I'm in the carb group. I can't believe I found the real problem after having them off so many times, everything is shiny just from handling them. At least I can have the four carbs off and on quicker than a NASCAR pit crew can change four tires.
69modelj
« Reply #16 on: January 18, 2010, 07:25:55 PM »
The worst feeling happens when you start the engine and discover the o ring you so painstakingly placed in it's proper location got bumped unknowingly during re-assembly. And it aint the damn bike's fault either ;D
Offline Kframe
  • Life is good!
« Reply #17 on: January 18, 2010, 09:17:06 PM »
Not really motorcycle related, but I hate it when I'm replacing the plug on the end of a power cord and I get all three wires perfectly snugged under the screws, and then I realize that the insulated housing or the clamp is still laying on the bench.
Doh!
 :P
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #18 on: January 18, 2010, 09:27:20 PM »
Cliff.
yup, left one of the o-rings from under the cam tower out. i didnt realize it till i had destroyed a set of cam towers. thank goodness for the frame kit.
Mark Twain - Notebook, 1894
« Reply #19 on: January 19, 2010, 01:59:04 AM »
i always forget to put the seat down,.and my wife screams at me!
Offline Syscrush
  • Sold. :(
« Reply #20 on: January 19, 2010, 04:32:57 AM »
I always estimate work in 3 phases:
1) The time to do it wrong.
2) The time to figure out what was done wrong.
3) The time to fix it.
Offline Hinz
« Reply #21 on: January 19, 2010, 05:32:04 AM »
bikes...cars....even posting replies on a message board.  It seems like almost everything in my LIFE i have to redo at least once.  No matter how much planning and research I do, inevitably it has to be torn down and redone.
At least it's not just me.
1976 CB750K
Has learned so far that..."complete" gaskets are never complete no matter where you get them, VHT Silver Case Paint is just as durable as painting your motor with chalk and cheap tire irons used with rim protectors are useless on 30 year old tires.
« Reply #22 on: January 19, 2010, 06:24:03 AM »
I had water running out of the bellhousing on my new pontiac engine, I pulled the trans to find the bad frost plug, it was the heater hose. There, I said it.
Offline IHWillys
« Reply #23 on: January 19, 2010, 10:12:23 AM »
Ouch.
I'm a chronic do it again type.  However, this is better than to do it wrong or poorly and then live with it/ignore it/hope it will be OK.
Ken
Offline Raul CB750K1
« Reply #24 on: January 19, 2010, 02:29:19 PM »
Many times I will come back on my steps just to check I bolted the door after I left home. I do it unconsciously, therefore I'm unable to remember whether I did it or not.
With bikes, I am very meticulous, but after things are closed, I start to wonder whether I put that tiny ball, or that washer, or whether the pistons were facing the right direction. To overcome this, I take tens of pictures along work. If doubt start lingering, I can always take the camera and check whether everything was as it should be.
