Here's my .02, for what it's worth...
Beware of going too low on the static compression, as that little motor doesn't have a bunch of torque to begin with. It would be a dog until you came up on boost. And since you probably have a B-25 unit, I'm certain that won't happen until late in 2nd gear. The IHI units were better sized to the small motors; quite frankly, the B-25 is oversized (CFM / % efficiency) when you run out the lines on a compressor map.
OK now all that being said, this can be a fun toy once you accept it's limitations. I'd keep the compression right where it is with stock pistons. Unless you want to fork out real $$ for forged units. Your #1 enemy here is detonation,
don't rattle the motor and you won't break it. That means GOOD GAS. No exceptions.
The better the fuel, the more boost you can get away with. More boost = more fun. Start low and continue to ease upwards with your boost settings, and
don't rattle the motor. Gee, did I already say this?
Make sure the carb doesn't starve for fuel EVER.
With proper tuning it would surprise most folks as to just how much pressure a stock motor can safely endure.
