Author Topic: Sandcast Restoration - Done (for now)  (Read 80030 times)
Offline markb
  • When I finish my current project I might be a
Re: Sandcast Restoration
« Reply #125 on: April 18, 2010, 05:11:27 PM »
I went home after another long day and decided to reward myself and take the K0 out for a ride.  It was saweet.  I love the sound of those 300 pipes.  I hope the no numbers on the sandy sound as good.  Now it's time to relax and make a to-do list.  I'm hoping to get her started up next weekend.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline markb
« Reply #126 on: April 19, 2010, 07:10:11 AM »
OK, so here's my to-do list, not neccesarily in this order but close.  It's actually a little longer than I thought it would be but a lot of these items should go fast.  I hope to have a little time a night or two this week and then hit it hard again on Saturday and hopefully be riding it on Sunday.
Connect throttle cable at handlebars
Put on grips and levers
Mount caliper and adjust
Connect brake hose at master cylinder
Fill brake fluid and bleed brakes
Check torque on rear axle nut and install cotter
Mount gauges
Finish bucket wiring and put in headlight
Install clutch, tach & speedo cables
Adjust clutch and install clutch cover
Put badges on side covers
Install muffler guards
Install petcock and run fuel lines
Put on mirrors
Put on labels
Change side stand spring
Put in turn signal bulbs and replace lenses
Adjust seat latch
Fill engine oil
Fill fork oil
Check tire pressure
Wipe off a million fingerprints
Fill gas tank
Check everything over
Start motor
Re-check everything
Go for test ride
Have a beer back at the garage while admiring bike
« Last Edit: April 22, 2010, 07:37:24 AM by markb »
Offline Magpie
« Reply #127 on: April 19, 2010, 07:13:43 AM »
And lots of these   ;D ;D ;D ;D ;D
Cliff.
Offline Damfino
« Reply #128 on: April 19, 2010, 10:10:38 AM »
Great thread! And that bike is sweet!!! 8)
Looking forward to the big finish, nice work Mark!
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Old Scrambler
« Reply #129 on: April 20, 2010, 01:14:28 PM »
Nice list but did you put air in the tires? ...........OK.......I do the same and check the items off as I go............usually find a few things to add before its complete.  Now for the anal questions..........are those Stanley headlight and turnsignal units?  Is the carb cable from Honda or aftermarket?  Is the foam in the seat pinkish-red?  I could go on but ..........this is not an AMCA contest!
Great job and a very enlightening thread.........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline markb
« Reply #130 on: April 22, 2010, 07:42:05 AM »
Thanks again guys.
Dennis, even after I'm "done" there are still some things I need and want to do.  But I want to get in running and then I can work on some of the other details at a more leisurely pace.
Had some time last night so my list is getting shorter.
Mount gauges
Put on mirrors
Put on labels
Adjust seat latch
Fill engine oil
Fill fork oil
Check tire pressure
Fill gas tank
Start motor
Re-check everything
Go for test ride
« Last Edit: April 26, 2010, 10:35:56 AM by markb »
Offline markb
« Reply #131 on: April 26, 2010, 10:44:20 AM »
Had a chance to work for a while on Saturday.  Ran into a snag with the master cylinder.  It wasn't pumping fluid and leaking out the handle end.  Wasted a lot of time on that.  Need to pull it apart and see what I did wrong.  Forgot I had to help a daughter move on Sunday so I didn't get as much done as I wanted to but the list is getting shorter.  Didn't take any pics because it doesn't look a whole lot different than my last ones.  Hopefully I'll be posting pics of the finished product soon.
Mount gauges
Put on mirrors
Check tire pressure
Fill gas tank
Start motor
Re-check everything
Go for test ride
« Last Edit: May 02, 2010, 03:06:35 PM by markb »
Offline markb
Re: Sandcast Restoration - Done (for now)
« Reply #132 on: May 02, 2010, 03:34:59 PM »
Between yesterday and today I knocked most of the items off the list.  I decided not to detail it yet in case it didn't start.  Hooked up the battery and put gas in it this morning.  Turned it over for a couple of 10 second bursts with the kill switch off to get a little oil moving and then tried to start it.  A couple of seconds and it fired.  A couple more tries and it stayed running but wasn't running good.  Shut it down and checked the pipes.  #1 & 2 were hot, #3 & 4 were cold.  Hmmm.  Can't be ignition or it would be #1 & 4 or #2 & 3.  Checked the fuel lines first and sure enough, the #3/4 fuel line was kinked.  Corrected that and she started right up.  Ran smooth at idle without the choke after about a minute.  Sweet!  I didn't do anything to the carbs, except draing the gas, when I took them off last fall so I was hoping they would still be good.  Seems to be.
Checked everything else over and the only other thing that wasn't working was the taillight.  Decided to check the easy thing first, the bulb, and that was it.  I'm not bragging (OK so I am a little) but after the work that was done and the things that could go wrong it was a pretty easy startup.  Took her out for a ride and it ran great.  The no number pipes sound great too.  Runs better and sounds better than the K0 does.  And it's true what they say, the red ones are faster!
So it's done (for now).  There's three things I still need to do which may wait until fall or winter.  Soda blast the carbs, replace the oil lines, and polish (brush) the rear hub and brake panel.  I'll probably sync the carbs, other than that she's pretty dang good.  It's fun just to be able to ride it.  Oh yea, and here's some pics.
And here's a couple of shots of the sisters.  I think the K0 (blue/green) was a little jealous of the sandy so I took her for a ride too.
« Last Edit: May 03, 2010, 04:10:43 AM by markb »
traveler
« Reply #133 on: May 02, 2010, 05:10:32 PM »
Looks GREAT!
Good to hear all went well.
Your next sand....what color?
~Joe
Offline Damfino
« Reply #134 on: May 02, 2010, 05:16:24 PM »
~Joe
Candy Gold of course!
Excellent work Mark!
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Magpie
« Reply #135 on: May 02, 2010, 05:23:55 PM »
One word.............WOW!
Cliff.
« Reply #136 on: May 02, 2010, 05:32:51 PM »
Excellent work Mark and a pleasure to watch the progress and outcome.
WOW indeed!
Andy
Offline bgfootball67
« Reply #137 on: May 02, 2010, 05:37:08 PM »
Nice work, sweet bikes....
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
Offline markb
« Reply #138 on: May 03, 2010, 07:34:56 AM »
Thanks guys.
The sandcast came out better than the K0.  It must be the practise.
The next project is sandcast #97.  It was originally red and I have the original 19 liter tank.  The outside was repainted but underneath is the original so I'm thinking I'd like to keep it red.  Then I would probably steal the other red tin off the later sandcast and move the blue/green (wrinkle tank and perfect original side covers) from the K0 to the later sandcast.  Then I would have a really nice red wrinkle tank for sale or I could use it when I do the K0 in the gold!  I love the gold but I don't think it was a production color on the sandcasts so I would keep those the correct colors.  Even then, the K0 is an early diecast, before the gold came out, but I could stretch the rules a little bit on that.  I'd like to have one of each color.  Just thinking out loud for now.  I'm a ways off on having to decide.
I'm going to start another thread on #97.  The one I just finished was pretty easy as far as restorations go.  It was in decent shape and pretty much all there and except for the repro airbox and side covers it's correct for its VIN.  #97 is pretty rough and is missing some unobtainable bits (but has a few good ones too).  It will definitely be a challenge.  But that's half the fun.  I'll just get it as close as I can.
Mark
« Last Edit: May 03, 2010, 07:37:14 AM by markb »
Offline kap384@telus.net
« Reply #139 on: May 03, 2010, 12:13:30 PM »
Gorgeous shot!  Great work.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Johnie
« Reply #140 on: May 03, 2010, 12:54:29 PM »
Beautiful Mark...wait...what is that I hear??? Oh yah, BOTM coming your way soon!!! Great job!!!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline fasturd
« Reply #141 on: May 03, 2010, 01:17:15 PM »
The red ones may be faster but I have to say I really like your blue one!
Great job and informative thread. My building buddy and I will be making one of your engine hooks shortly.
Thanks for all the info.
And good luck at the VJMC show.
Bill
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
Offline goaarongo
  • zen and the art of angle grinding
« Reply #142 on: May 03, 2010, 01:26:16 PM »
Amazing results.  Thanks for sharing as much as you did.  Always got excited when I saw this thread pop back up to the top of the list.   Very inspirational!
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #143 on: May 04, 2010, 07:32:36 AM »
Looks great Mark!  Nice work :o.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline markb
« Reply #144 on: June 08, 2010, 01:59:19 PM »
Thanks to all of you again for your compliments and to those who voted for the bike for BOTM.  I thought some of you may be interested in my experience at the local VJMC show last month.  I brought the K0 and the sandcast.  Lots of really nice bikes.  I think there were 80 entered, might have been more if it wasn't a rainy morning.  Met a couple SOHC4 members, vance and fasturd, and plenty of other nice people.  I had plenty of fun and it is a fun show, in otherwords not serious.  But I was taken completely off guard when the sandcast took Best In Show.  I've been enjoying having it together and riding it but that was the icing on the cake.  I'm waiting for the club to post pictures from the show and then I'll post a couple here.
Mark
« Reply #145 on: June 08, 2010, 02:09:36 PM »
WTG!  (Way to GO!)
Offline Magpie
« Reply #146 on: June 08, 2010, 02:29:42 PM »
Good for you Mark! well done.
Cliff.
traveler
« Reply #147 on: June 08, 2010, 07:02:55 PM »
Sure have a nice stable going here
~Joe
« Reply #148 on: June 08, 2010, 07:29:44 PM »
Great effort and quality takes the prize!  A very informative thread.  Yes, the red ones are always faster!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline madmatt
« Reply #149 on: October 02, 2010, 11:03:45 PM »
Markb ,
Very nice!  Thanks for taking the time to post all the great info.  I also have 3 K0's 2 of them sandcasts.  I have restored the 2 sandcasts, both ground up resto's.  I am thinking about what to do with my diecast, it's a decent daily rider at the moment.
I have been a little short on the $$ to buy all the correct pieces for the Sandcasts, but the motors and frames are correct and as $$ become available I will be buying the Yamiya seats and pipes, etc.
I just bought the Yamiya instrument plastics and face plates and the quality is excellent. Like everything else, once you see one restored to absolute new, then nothing else will do.
Your work is gorgeous and inspiring!
Matt
