Author Topic: performance parts (Pics)  (Read 3715 times)
Offline 78 k550
Re: performance parts
« Reply #25 on: January 23, 2010, 03:40:42 PM »
We should pull that pan. I don't have a gasket but while it is out it would be the smart thing to do. What you doing tomorrow Jerry, I'll make dinner.  hehe. Terry you already get dinner.
We pulled the nuts and all but not the 6 inner one's under the pucks.
I don't think we broke the seal on the head gasket.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #26 on: January 23, 2010, 06:12:49 PM »
Hummh, not sure. Family. What time are you guys starting? Is there room in that garage of your's for 3 of us?! I should be taking mine down. I actually got motivated and removed and drained my tank today ::) That's a start  ;) I think seeing your stuff lit a small fire. If I can make it I can bring a gasket. What else is on your list?
Offline 78 k550
« Reply #27 on: January 23, 2010, 11:32:58 PM »
call me in the morning.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline cb650
« Reply #28 on: January 24, 2010, 08:02:36 AM »
I'm hangin this morn.   I'll eventually get motivated.
Cool on the washers.
Offline 78 k550
« Reply #29 on: January 24, 2010, 09:07:47 AM »
ok cool no problem
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #30 on: January 24, 2010, 10:20:25 AM »
Damn, you guys get up early!
« Reply #31 on: January 24, 2010, 10:30:23 AM »
The bolt holes you circled in red are very easy to strip, be sure to check the threads and be careful torquing them down. I tapped the 4 center bolts for new 1/4" fine thread bolts.
Offline 78 k550
« Reply #32 on: January 24, 2010, 12:18:35 PM »
Whats the deal on the 4 copper washers I need for the install of the head. I don't think they where there. I can pick them up at Ace? Something about copper washers on 5,6,7,8,
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
« Reply #33 on: January 24, 2010, 03:54:59 PM »
Well we pulled the pan and some gunk in there from the tensioner rubber wheel. and ended up pulling the head and cylinder. pics to follow.
So look's like stock pistons with the RC237 cam.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #34 on: January 24, 2010, 04:13:09 PM »
Paul
G'Day Paul, the copper washers are there to seal those studs as they are also carry oil. They are the same thickness as the steel washers, but if you can only get thin ones, just install a steel washer over it. Bummer about the stock bore, I was hoping that you had at least an 836, or even a 900 kit. Cheers, Terry. ;D
Offline cb650
« Reply #35 on: January 24, 2010, 04:24:42 PM »
It only had one in it when we took it apart.  And it looked like $hit.
Offline 78 k550
Re: performance parts (Pics)
« Reply #36 on: January 25, 2010, 05:33:56 PM »
Here are some pics of the cylinder and valve's
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
« Reply #37 on: January 25, 2010, 05:36:39 PM »
One of the valve's.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
« Reply #38 on: January 25, 2010, 09:27:55 PM »
Paul
Thank's Terry,
I'll pick some up for the buildup. Yea too bad about stock piston's.
It has a nice copper head gasket.
cylinder walls have some nice honeing marks and very little to no lip.
Paul
« Last Edit: January 25, 2010, 09:31:40 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #39 on: January 25, 2010, 11:56:50 PM »
Can you take pics of the pistons at the top of the stroke?
Sam. ;)
« Reply #40 on: January 26, 2010, 02:37:03 AM »
They look just like stock F2 pistons Sammy. ;D
« Reply #41 on: January 26, 2010, 03:03:56 AM »
I wouldn't know what an F2 piston looked like if one hit me in the face :D :D :D
Sam. ;)
« Reply #42 on: January 26, 2010, 03:57:21 AM »
I've got a couple spare here Sam, I'll send you one if you promise to post a pic of you hitting yourself in the face with it! ;D
« Last Edit: January 26, 2010, 05:17:52 AM by Terry in Australia »
« Reply #43 on: January 26, 2010, 04:16:57 AM »
Shame I don't kmow how to post pics :D :D :D :D
Sam. ::)
