Author Topic: Question regarding signifigance of butterfly valve number stampings.  (Read 453 times)
Offline HondanutRider
Looking at the carb rack on my CB350F I see that the butterfly valves each have a number - either a 1 or a 2.  The spare rack I have also has these numbers on the butterflies - but they are in carb different locations.
Are these numbers significant?  Do they designate the size for proper fitment to the carb body?  If I switch bodies, should I ensure the correct butterfly label is fitted?
Re: Question regarding signifigance of butterfly valve number stampings.
« Reply #1 on: January 22, 2010, 07:50:53 AM »
Well, I finished changing one body on my rack and made sure the same butterfly was installed in the replaced body as it originally came with.  I compared the diameter measurements between a #1 and a #2 stamped valve, and they do seem to be of slightly different sizes.  Not much, but probably makes a difference if too large (i.e. could bind).
