Author Topic: 750 Inlet Stubs  (Read 526 times)
Offline beveldrive
750 Inlet Stubs
« on: January 20, 2010, 08:35:42 AM »
Anyone ever sucessfully removed the screw-in inlet stubs on the 750 cylinder head?
I put a large socket and breaker bar on mine and cant shift 'em :(
Re: 750 Inlet Stubs
« Reply #1 on: January 20, 2010, 08:47:42 AM »
I've done it more than 10 times. ;) You need to thoroughly heat the area and put the head in a vice or clamp it to a metal table (to hold securely).
Offline markb
  • When I finish my current project I might be a
Re: 750 Inlet Stubs
« Reply #2 on: January 20, 2010, 08:56:30 AM »
I've looked at that too.  It looks like there is some grinding or rough polishing inside after they're assembled.  Will one from another head just go right in without any additional work?
Thanks,
Mark
« Last Edit: January 20, 2010, 09:14:33 AM by markb »
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Re: 750 Inlet Stubs
« Reply #3 on: January 20, 2010, 08:59:46 AM »
I took a set out, a few ended up stripped. Have to weld them back in.
 I wouldnt take them out if I didnt have to, unless you want to make bigger ones.
Offline beveldrive
Re: 750 Inlet Stubs
« Reply #4 on: January 20, 2010, 09:00:41 AM »
Thanks MRieck
Trouble is, I've just finished torquing the head down  >:(
Do you think you method will still work?
