Author Topic: which head do I have?  (Read 965 times)
Offline hapakev
  • Your Standard
« on: January 20, 2010, 11:29:07 AM »
I recently picked up a 73K motor and was a little baffled.  The head has 5 round bars on the side of the head and looks like other 73 heads. I searched the threads on the forum for head markings and found pictures similar to what I have, but mu exhaust ports have studs.  The 73 heads I found in the searches have spigto style exhaust mounts.  Do I have a different year head?  did the PO put in studs?
Also I could not find any info on these markings, looks like R13 and 63 or 29?
Here is the almost complete engine number :)
Smoking Jack
1978 CB750F(ish)
Offline beelsamin
Re: which head do I have?
« Reply #1 on: January 20, 2010, 12:27:00 PM »
The engine number would be a 1973...head could have been changed somewhere in the past?
1977 Suzuki GT750
1972 Honda CB750 K2
1978 Honda CB550K
« Reply #2 on: January 20, 2010, 12:38:54 PM »
That is an earlier head....1973 looks about right.
Offline cookindaddy
  • I sure love this bike!
« Reply #3 on: January 20, 2010, 01:43:48 PM »
hapakev:
I'm trying to learn from you here - what is a "spigto" style exhaust mounts? I searched here and am asked if I meant "spigot"? I have the studs on my 78 but I'd like to understand what was used earlier. Thanks.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline hapakev
  • Your Standard
« Reply #4 on: January 20, 2010, 02:10:48 PM »
The earlier spigot style has an adapter that bolts to the head, then the exhaust header clamps to the adapter.
Mreick:  All of the 73 heads I have seen have the adapter that has screws that thread into the head, but mine has studs for the exhaust like a 77-78 head.  I need to get a header for this engine, but dont know which to look for.
here is an example of what I mean.  This is advertised as a 73 head, but the exhaust spigots screw into the head.
http://cgi.ebay.com/ebaymotors/Honda-CB750-CB-750-73-CB750K-Cylinder-Head-Valves_W0QQcmdZViewItemQQhashZitem5d26ea433fQQitemZ400084845375QQptZMotorcyclesQ5fPartsQ5fAccessories
« Last Edit: January 20, 2010, 02:14:02 PM by hapakev »
Smoking Jack
1978 CB750F(ish)
Offline hapakev
  • Your Standard
« Reply #5 on: January 20, 2010, 02:52:06 PM »
is it possible that its a 74 head?  I dont know if it means anything, but this auction says for 74-78 and looks like the exhaust stud application as apposed to the spigot style
http://cgi.ebay.com/ebaymotors/Honda-CB750-F-K-4-1-Ch-BLK-MAC-Exhaust-System-74-78-750_W0QQcmdZViewItemQQhashZitem2558071b5cQQitemZ160390650716QQptZMotorcyclesQ5fPartsQ5fAccessories
Sorry, after reading further, I think this auction is a typo.  Still dont know what I've got.  My header from my 78F motor looks like it bolts up.  I haven't tried it with gaskets, but it seems damn close.
« Last Edit: January 20, 2010, 02:56:04 PM by hapakev »
Smoking Jack
1978 CB750F(ish)
Offline hapakev
  • Your Standard
« Reply #6 on: January 20, 2010, 06:26:01 PM »
Im still cornfused.  Does anyone else have a 73K head with studs?
Smoking Jack
1978 CB750F(ish)
« Reply #7 on: January 20, 2010, 06:40:20 PM »
Someone could have removed the original spigots to put a Kerker on etc. No big deal at all. The exhaust ports are the same in regard to placement for all years.
Offline hapakev
  • Your Standard
« Reply #8 on: January 20, 2010, 06:45:37 PM »
Thanks MReick, in regards to spacing of the collars and header, can I double up exhaust gaskets if I have to?
Smoking Jack
1978 CB750F(ish)
« Reply #9 on: January 20, 2010, 07:06:59 PM »
I call that a 72 and down head..
It is starting to look like early 73 may have used them, but late did not. Also not the top fin is different above the exhaust on the front.
Spigot have been swapped with studs, use what you need for your exhaust available..
Offline hapakev
  • Your Standard
« Reply #10 on: January 20, 2010, 07:21:23 PM »
Cool, thanks guys.  I appreciate the info, as always
Smoking Jack
1978 CB750F(ish)
