Author Topic: oil cooler lines I.D. : flow and pressure  (Read 2541 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« on: January 21, 2010, 03:05:45 PM »
hey guys- i'm fitting a new cooler to the 718cc engine (cb550) and want to make sure i don't create a bottleneck. the cooler is manufactured as an aftermarket part for rs50's and rs 125's,which my shopmate races. these are much smaller bikes obviously, but i assume would need similar pressure and flow through the cooler. the lines that came with the cooler used 10mm banjo bolts, which i thought would provide far too small an orifice for all of my oil to flow through. the cooler coming off had 3/8" I.D. hard copper lines.
the plan is to go with dash 4 lines, which have an internal I.D. of .22". any larger than this will be pointless due to the size of opening at the cooler. what size lines do you guys usually run, and will dash 4 be adequate?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Re: oil cooler lines I.D. : flow and pressure
« Reply #1 on: January 21, 2010, 03:13:59 PM »
I run -6 on my Earls Paul. -8 on the earl's that is on my FJ
Offline paulages
  • 1976 cb735
« Reply #2 on: January 21, 2010, 06:49:12 PM »
i'd like to go with -6, but like i said the size of the orifice at the cooler is only .25" anyway... do you think -4 is too small?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #3 on: January 21, 2010, 07:33:05 PM »
Yes
Offline paulages
  • 1976 cb735
« Reply #4 on: January 21, 2010, 09:34:27 PM »
Yes
hmmm. ok, back to the drawing board.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
