Author Topic: rear brake rod inter-changability???  (Read 2557 times)
Offline timdhawk
  • 1978 CB750K
« on: January 24, 2010, 07:05:39 AM »
will a rear brake rod of a 74 cb750 fit/work on a 78 cb750? are the brake rods different at all between the years?
In deeper than I should be...
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: rear brake rod inter-changability???
« Reply #1 on: January 24, 2010, 07:29:57 AM »
I'm pretty sure they're all the same length.
  The mounting bracket on my 71 was all the way up against the pivot point, and the one on a 77/78 is an inch or so away from it.
I have an 80 swing arm and its about 2.5 inches away from the pivot and uses the same arm.
Wait a minute!!!  ...are you talking about the actuator rod that moves the shoes? cause they're different lengths by about 2-3 inches.
« Last Edit: January 24, 2010, 07:32:01 AM by Industrial Cafe »
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: January 24, 2010, 09:06:02 AM »
Compare the part numbers.
mystic_1
- John Augustus Shedd
Offline timdhawk
  • 1978 CB750K
« Reply #3 on: January 24, 2010, 01:48:53 PM »
Industrial,
I mean the skinny rod from the brake pedal to the actuator lever - with the spring and adjuster nut.
mystic_1
Yea, I did this once I found a sight that listed the numbers of unavailable parts. They are the same part niumber.
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: January 24, 2010, 01:53:45 PM »
the 77-78 are longer than the 76 on back. because of the longer swing arm.
the early 80's model CB750s with the drum brake had an even longer one (in case you're doing rear sets with a drum)
« Last Edit: January 24, 2010, 01:56:16 PM by Industrial Cafe »
Offline Toxic
« Reply #5 on: August 01, 2010, 06:41:51 PM »
At the risk of resurecting a somewhat old thread ... what is the measurement from the front on the brake rod to the front of the spring stop on a pre- 1977 cb750?
I have a 77 rod that I am modifing to fit on my 72.
Thanks for the help
Gary
Offline Cuts Crooked
  • Cowboy Biker
« Reply #6 on: August 01, 2010, 07:20:24 PM »
1+ on that. Seems like I reccommeber that the 77/78s are two inches longer overall?
Cuts Crooked
CB 750K8
Old Bikes 'n Old Guns are my first two loves :)
Offline Toxic
« Reply #7 on: August 02, 2010, 04:21:46 AM »
I am going to grind off the foreword spring stop and run some new threads up the rod until I have the same length of rod as a 73.
If someone knows the distance of the rod from the foreword spring stop to the front end of the rod that would help
  • Like a well oiled
    • Undead Asphalt
« Reply #8 on: August 06, 2010, 06:05:07 AM »
nobody knows?   apparently it's a mystery.
make a thread with "how long is a 77-78 drum brake rod?" as the subject, you'll get an answer 'right quick'.
Offline mrrch
« Reply #9 on: August 06, 2010, 07:52:44 PM »
I can measure my 77 CB750K rod on Monday when I'm back at work.
my build
  • Like a well oiled
    • Undead Asphalt
« Reply #10 on: August 07, 2010, 06:46:17 AM »
:) :) you're a funny guy
  • Like a well oiled
    • Undead Asphalt
« Reply #11 on: August 07, 2010, 06:48:49 AM »
oh hey thanks man!
Offline mrrch
« Reply #12 on: August 10, 2010, 09:03:27 AM »
Sorry I forgot about this yesterday. My 77 CB750K rear brake rod measures  23.5 inches in length and the threaded portion is 4 inches.
The other thing I've noticed is the brake arm on the drum is shorter on the 77 compared to an earlier one (4 inches compared to 5 inches)
my build
Offline Toxic
« Reply #13 on: August 10, 2010, 12:00:32 PM »
just in case anyone else is in the same boat. Stuck with a 77 rod and trying to make it work on an early CB750
I took a 6mm die and after removing the raised bump that the spring end rest against, I ran an additional 1.5 inches of thread up the rod.
I used a nut at the end of the thread so that the spring end now rests against this.
Not stock but it works
  • Like a well oiled
    • Undead Asphalt
« Reply #14 on: August 11, 2010, 06:38:31 AM »
just rotate the lever. that's what I did on mine.
(file some teeth on the lever if necessary)
