it's gotta be a restriction in the fuel system, go over there and help him.
pull the line off the tank and see if it drips out the petcock.
put the line back on the petcock and check for any loops or horizontal lines in the fuel line between there and the carb. turn on the fuel to see if any comes out at a good rate of flow.
If that's good, pull the bowl.
with the bowl removed and the fuel line attached to the carb you should be able to open the petcock again and get a good dribble of fuel pouring out.
If not, check the float valve for debris.
that's all I got for ya.
