After some great motivation from some folks on here, I've decided to stick with my build.
I pulled everything off the frame, EXCEPT the chain. It looks like the PO welded a hard tail with the chain attached to the former swingarm? I can't find a master link so I have a couple of questions...
1. Assuming I'll have to cut the chain off so I can get to refinishing the frame, is this the way it's
supposed to be? That is, when I put it back together, should the chain be wrapped around the swingarm? I couldn't find any pictures in parts catalogs/service manuals/SOHC forums to answer.
2. If I am supposed to put it back together this way, that means I have to use a new chain that has a master link, right?
3. Can anyone recommend sources for this chain?
