Author Topic: 1976 CB750 aka "The Honda in the barn" carbs  (Read 2038 times)
LouB
« on: January 26, 2010, 05:26:11 PM »
Okay, it's carb time and I need some opinions...I have read to only use OEM rebuild kits, but I am having a tough time finding them(specifically for the K6). So, should I just clean them and put some new gaskets (which I can find)? They are a filthy mess on the outside and I haven't torn into them yet, but from what I can see, they look pretty decent. Anyway, opinions and advice are always welcome!  ;) Thanks.
Re: 1976 CB750 aka "The Honda in the barn" carbs
« Reply #1 on: January 26, 2010, 06:02:49 PM »
There will be no need to replace the inward parts, except possibly the float valves (and maybe their seats) if corroded so they leak and won't shut off.
Whatever you do, dont use the Keyster brand of slide needles and needle jets: they are not the right calibration for the CB750 and have caused endless grief for dozens of our members. The needles never "wear out", and even if the needle jet wears itself oval, you can pull it out and reverse it 180 degrees and it will work fine again. It took over 100,000 miles on mine to finally make this wear measurable: first I lowered the needles one notch, which worked quite well: then I turned the needle jets around and it fixed things up. Then RXman found a set of needles and sent them to me as a gift, so I installed them. (I'm currently thinking of going back to the slightly worn ones again, because it had better midrange performance with the slightly increased fuel flow in my favorite driving ranges!)
I recently bought some sets of carb bowl gaskets from one of our advertisers, PartsNmore. They work perfectly for $5 per set! Find the ad and click it on our site, so it helps pay our server fees...  ;)
LouB
« Reply #2 on: January 26, 2010, 06:49:13 PM »
Gotcha  ;D Thanks for the advice! That's what I wanted to hear, which is a rarity in itself! I'll give it a shot and let you know how it goes. While I have your attention, what's your opinion of the K&N air filters? They are pretty pricey, but they have their benefits. Do you think they are worth it?
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: January 27, 2010, 01:48:17 PM »
Be sure any carb parts you by are for a 750A. Carbs are much different from standard CB750
Fonda Honda
Offline grumburg
« Reply #4 on: January 27, 2010, 01:50:04 PM »
Sorry, I thought you meant 750a (automatic).  I guiss i ned nw glassis
Fonda Honda
