Author Topic: Can't get case apart  (Read 869 times)
Offline MattFreeman
  • What Have I Done?
« on: January 28, 2010, 03:36:27 PM »
I'm trying to split the cases on my 76 CB750F and I'm having a tough time and looking for some advice.
I've got everything off that needs to be, I think. Cylinder, countershaft holder, shifty/neutral bits, points, clutch (not the holder), stator, all the bolts, ect.
Here's the hitch: I can get the stator side apart easily, but it's hanging up around the back side of the points area. It will come apart a few mm but no more. Is the seal around the points shaft holding me in place?
It almost seems like there is something soft/flexible creating the problem, rather than something solid . Like it would go if I forced it, but I don't wanna do that.
Thanks in advance, I seem to thank God for this site at least once a day. You guys are making the bike possible.
MF
« Last Edit: January 28, 2010, 06:25:27 PM by MattFreeman »
Offline OldSchool_IsCool
  • Really feeling like an
Re: Can't get case apart
« Reply #1 on: January 28, 2010, 05:50:08 PM »
MF,
Could there be a bolt hiding somewhere?  Count the bolts in your parts bucket and compare it to a parts fiche to see if all bolts are accounted for.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline MattFreeman
  • What Have I Done?
« Reply #2 on: January 28, 2010, 06:06:07 PM »
I don't think it would come so far apart it still had a fastener in. I can open the stator side at least an inch.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: January 28, 2010, 07:53:40 PM »
Could be hanging up on one of the locator dowels.  There's one just behind the points area.
Failing that, wedge the case open with some popsicle sticks or something and then peer in there with a flashlight.
mystic_1
- John Augustus Shedd
Offline MattFreeman
  • What Have I Done?
« Reply #4 on: January 29, 2010, 03:23:17 PM »
Well I gott'um open. The seal on the points side of the case was stickin'.
A little pryin' with a old rusty flathead and pop! ;)
Now I gotta start spendin' money.
