Author Topic: Easy way to remove tach drive seal??  (Read 1888 times)
Offline Magpie
« on: January 29, 2010, 08:02:23 PM »
This is for an early sandcast 750 engine. The valve cover is much thinner than later ones especially around the tach drive hole. I've already knocked a sliver of metal away trying to get the seal out. I wonder if it needs to be replaced at all since I haven't seen others leak there however.............I do have a new seal and I've come this far. Any easy ways to remove a 40 year old seal?
Thanks,
Cliff.
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Easy way to remove tach drive seal??
« Reply #1 on: January 29, 2010, 08:05:08 PM »
Dental pick worked for me.
Offline GammaFlat
« Reply #2 on: January 29, 2010, 08:11:56 PM »
I used a small wood screw.  Go directly into the seal and maybe do 2 - one at 12 o'clock and one at 6 o'clock.  Use pliers to pull the wood screw.  Be real careful about not scarring the aluminum with the screw.
Good luck
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline Johnie
« Reply #3 on: January 29, 2010, 08:13:53 PM »
I drilled a real small hole to get the screw started. Then it pulled out. I like the idea of the mechanics pick.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline 1080
« Reply #4 on: January 29, 2010, 08:15:20 PM »
« Reply #5 on: January 29, 2010, 08:50:27 PM »
Cliff, maybe I can mail one...
Offline nokrome
« Reply #6 on: January 29, 2010, 10:05:23 PM »
you guys are funny ;)
   i used a big wood screw and screwed it into the hole that was already there
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline nokrome
« Reply #7 on: January 29, 2010, 10:07:16 PM »
of course i had the cover off the engine  ;D
Offline Magpie
« Reply #8 on: January 29, 2010, 11:36:32 PM »
I finally used a pick, thank you dukiedook, and added more courage and out it came. The new one went home with the aid of a 10mm socket gently pushing it down the hole, aided with some PB Blaster.
Thanks for your quick response guys!
Cliff.
« Reply #9 on: January 30, 2010, 03:09:11 AM »
No problem, I have found those picks to be quite useful on all my vehicles.
Definitely a good find for a couple of bucks.
Offline Johnie
« Reply #10 on: January 30, 2010, 05:18:08 AM »
Cliff.
Here is what I use for pushing the new one back in. It is an old tach cable end. I guess you can make a tool out of anything you don't toss out.  ;D
Oshkosh, WI  USA
Offline Magpie
« Reply #11 on: January 30, 2010, 09:14:18 AM »
Good idea Johnie! The 10mm socket I have fits the hole quite nicely, the only thing I could think of at the time. I also used several sockets to help replace the seals in the covers. Slowly, slowly....................
Cliff.
