Author Topic: What carbs fit a 1975 CB360?  (Read 2358 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: January 30, 2010, 01:57:02 PM »
I'm picking up where another local mechanic couldn't finish and the bike arrived somewhat disassembled.
The slides and hard-to-find diaphragms are missing, so I'm probably going to start hunting for another set of carbs. What other twins from this era had the same carb bodies? I can swap in the jets from the stock ones if that's the only difference between another model.
1974 CB550
Forever West
Saml01
Re: What carbs fit a 1975 CB360?
« Reply #1 on: January 31, 2010, 08:32:22 PM »
I would imagine carbs off the 350 would work.
cbrace0012
« Reply #2 on: February 12, 2010, 03:04:55 PM »
Carbs off the 350 won't work unfortunately.  I would stick with the stockers and try to get some decent used diaphragms off of ebay.  I see carbs on there a lot going for like $20 to $50 which would be worth buying if you could trust the seller to check the diaphragms out for you by shining a light through them.
  • The Stumped
« Reply #3 on: February 13, 2010, 02:07:36 AM »
Just did that, thanks. Those diaphragms are hard to come by!
1974 CB550
Forever West
