If you're doing a true restoration, aren't you sort of obligated to go with actual Honda parts? I've been considering reworking my swingarm also, mainly because I like the thought of having something a little more durable there, but I'd be hard pressed to tell you whether mine are "worn out" or even broke in since the odometer says 20k, and while I'm sure it happens, probably a lot more frequently on bikes that spend a lot of time stressing those bushings in hard corners, or moto-crossing and such, really havent heard of very many swingarm failures, although it is high on the list of overlooked parts to lube. Other than the occasional passing thought, I haven't looked into it yet, but according to the quote, bronze bushings don't meet spec "without work" either, so what is involved in that work? why could you not do the same work to the factory bushings? I know how you feel about wasting money and time,but my experience has been if you bang it together today, you'll be banging it back apart again tomorrow....don't let them blues gitcha!! I'd recommend some Winter Ale...
