Author Topic: anybody install the cycle x power arc?  (Read 1990 times)
Offline hapakev
  • Your Standard
« on: February 03, 2010, 08:41:05 AM »
What plug wires are you using?  The kit comes with the caps, but no wires so I need to buy some.  The site says to use carbon core resistor plug wires.  Is ferrite core an acceptable substitute?
Smoking Jack
1978 CB750F(ish)
Offline Steve F
Re: anybody install the cycle x power arc?
« Reply #1 on: February 03, 2010, 09:42:04 AM »
This is a place where you can get nice wires with the plug ends already on.  You cut to length and add your coil ends.
http://www.z1enterprises.com/catalog.aspx?pid=MFDY4
Steve F
Offline Silverback
« Reply #2 on: February 03, 2010, 12:54:41 PM »
I just bought some generic carbon core wires at Autozone.
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline nokrome
« Reply #3 on: February 03, 2010, 01:38:45 PM »
  if you go to the power arc website they recomend that you use only magnacore wires
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline Deltarider
« Reply #4 on: February 03, 2010, 02:01:08 PM »
I was warned (by an old and experienced mechanic) with our bikes to stay away from carbon cables. No experience myself, just passing it on.
« Last Edit: February 04, 2010, 05:26:09 AM by Deltarider »
CB500K2-ED Excel black
Offline Inigo Montoya
« Reply #5 on: February 03, 2010, 09:45:57 PM »
Wouldnt carbon core be considered a resistor wire?
Offline cb750k77
« Reply #6 on: February 03, 2010, 09:51:55 PM »
you guys are all thinking about stock coils.... not power arc.... power arc is a modern coil it does fine with those special wires use what it says.... the responce time of coil depends on it...
CB750k77 rebuilt (almost)
Offline Deltarider
« Reply #7 on: February 04, 2010, 03:37:34 AM »
Actually I was thinking about vibrations and carbon being brittle. Even copper wires suffer from vibrations and will loose effective diameter over time.
« Reply #8 on: February 04, 2010, 05:19:25 AM »
 Ignitions like the Power Arc and Dyna 2000 cannot use copper core spark plug wires. I have used both the Dyna "Grey" wires and Taylor Spiro wires. The Taylors come in various colors and have a molded in plug cap.
Offline hapakev
  • Your Standard
« Reply #9 on: February 04, 2010, 10:23:02 PM »
Mreick, where do you get the taylors?  do you have an online source you use?
Smoking Jack
1978 CB750F(ish)
Offline hapakev
  • Your Standard
« Reply #10 on: February 04, 2010, 10:26:35 PM »
nokrome-I think it says that they are the onlt spiral wound wires you can use with the power arc, if I remember correctly
Silverback-that might be the way I go. Thanks
Smoking Jack
1978 CB750F(ish)
Offline nokrome
« Reply #11 on: February 05, 2010, 08:37:21 AM »
good point !!
