Author Topic: Help removing carbs on 400f  (Read 1024 times)
Offline mb3000gt
« on: January 08, 2006, 04:26:11 PM »
Can someone give me some tips on getting the carbs out, without tearing anything. I should be pulling up and out the right side, right? thanks in advance.
Teach
Re: Help removing carbs on 400f
« Reply #1 on: January 08, 2006, 04:32:16 PM »
I use a broomstick between the carbs and the motor to pry mine out.  Just go slowly and you won't rip the intake rubbers, or if you do you should replace them anyway  ;D  Works like a charm!
Offline heffay
« Reply #2 on: January 08, 2006, 04:41:51 PM »
put your thumbs on the intake manifolds and the rest of your fingers on the carb body (or vice versa) and press the 2 apart.
elbow grease my friend!
