Author Topic: will i need to change my cam chain or shorten it if i run thinner gaskets  (Read 1639 times)
Offline bucky katt
  • i am a pastafarian!
    • facebook
i have found thinner than stock, copper head gaskets and thinner than stock (.005" ) base gaskets and other than checking clearances between piston and valves and head, is there anything else i need to do? i am looking for as much compression as i can get with a relatively stock motor and bore. and a honda (cb750f0 cam)
« Last Edit: February 04, 2010, 01:44:51 AM by bucky katt »
Mark Twain - Notebook, 1894
Re: with a good sealant, can i run 750 cylinders without a base gasket?
« Reply #1 on: February 04, 2010, 01:39:48 AM »
ive done it to a 550,clean all the surfaces perfectly with metholated spirit,ive run the motor for half an hour,no leaks,havent used it in a bike yet.dont bulk it on,a thin even smear,keeping out of the oil gallery areas.
Offline bucky katt
    • facebook
Re: will i need to change my cam chain or shorten it if i run thinner gaskets
« Reply #2 on: February 04, 2010, 01:48:24 AM »
looks like a head gasket as thin as .005" is also available as well as the .005" base gasket. are copper gaskets compatible with street use?
Offline BLUE71TURBO
« Reply #3 on: February 04, 2010, 02:16:12 AM »
Copper gaskets are the only way to go in my opinion. As for the cam chain, no you won't need to change it or shorten it.
Offline bucky katt
    • facebook
« Reply #4 on: February 04, 2010, 06:46:14 AM »
cool, so i can get a bit of a compression increase just by going to MUCH thinner gaskets. i'm thinking .005" thickness base AND head gaskets. because the motor is in such good mechanical condition i dont want to have to buy new pistons and possibly re-bore for more compression. well, if i can get this home stereo equipment sold, dynoman is going to be selling me a new head gasket to start with. if i dont have to pull the barrels i wont. oh, and some modeling clay for checking clearances.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #5 on: February 04, 2010, 07:06:25 AM »
Won't have to change chains, but will have to time a bid differently. Timing advances a little with thinner gaskets.
No.
Offline bucky katt
    • facebook
« Reply #6 on: February 04, 2010, 07:11:59 AM »
ok so the adjustable cam sprocket i did needs to go on now then?
Offline bucky katt
    • facebook
« Reply #7 on: February 04, 2010, 09:01:40 AM »
i love it when a business owner or operator has the integrity to try and talk me OUT of buying a part because they dont think it would be satisfactory for me. the reply i got when asking about the thin copper head gaskets was this
"We do not have thinner head gaskets in CFM-20 fiber material. We can make a thinner copper head gaskets, but do not recommend them. They are strong, but not good on oil control."
that is cut and pasted directly from the email reply i recieved, in less than an hour at that.
« Reply #8 on: February 04, 2010, 09:34:06 AM »
Copper is probably first choice where the top end is off often (racing applications). On the street where you want oil tight the fibre will probably get the nod. Instead of a copper base ask them for viton coated steel, not sure 0.005" is available though
Offline bucky katt
    • facebook
« Reply #9 on: February 04, 2010, 09:39:46 AM »
the thinnest in the coated steel is .010" any clue as to how thick the original one is?
« Reply #10 on: February 04, 2010, 09:45:07 AM »
Are you milling the head? If you want to save time and bux, try to lap it.. get a big flat surface and big sandpaper (like stroke sander castoffs or similar).
 Blue the head or make felt pen marks, work it a bit and check if its near flat, work it till flat.
 I am not a big fan of milling heads unecessarily.
Offline bucky katt
    • facebook
« Reply #11 on: February 04, 2010, 10:02:47 AM »
Mrieck suggested trying the thinner base gasket first. then try milling a bit off. it's possible, if the stock base gasket is that much thicker, that just the thinner base gasket will work. this is all a long ways off though as all i want to do right now is ride the thing.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #12 on: February 04, 2010, 11:02:01 AM »
Doesn't cost much to have the head decked. May want to look into that.
No.
« Reply #13 on: February 04, 2010, 06:49:31 PM »
Stock base gasket is 0.5mm (0.020")
« Reply #14 on: February 04, 2010, 07:02:30 PM »
I wouldn't bother using copper unless you're getting them really cheap Fuzzy, I've never had a problem with head or base gasket leaks because I torque 'em down to 20 ft lbs, (in small increments) leave them overnight, back 'em off, then torque 'em down again next morning, and by now I've crushed them fat gaskets down to half their original thickness anyway. Cheers, Terry. ;D
Offline bucky katt
    • facebook
« Reply #15 on: February 04, 2010, 09:42:15 PM »
50 to have it milled. i think i'm going to send the 75 750f head to have that done, and new guides at the least.
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #16 on: February 05, 2010, 08:39:26 AM »
My .02 is to go for a zero deck first. Deck the block before the head, get that tight squish band working for you.
Don't think I'd be inclined to use a head gasket paper thin! If chamber volume is that important, mill the head & use a decent .040" copper gasket, for sure you won't have leaks and you can reuse that gasket for years to come.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
