the sony in my garage has a and b... but can run either or both... its fairly old, late 80's. if all else fails you could calculate the ohms, and run them either series or paralell off just a. check the ohms though as you could overheat components if your not careful! i can help with the ohm calculation if needed, just give me some info... make and models..
