Author Topic: Valve Questions  (Read 966 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
Valve Questions
« on: February 05, 2010, 08:36:13 PM »
1975 CB550
I'm putting in new rings and I have the head off. I was wondering how can I test to see if my valves need to be redone? Is there a way I can test this without taking it all apart?
When I got the bike it would smoke on and off and it ran horribly. The carbs were completely gunked up and I rebuilt them but I don't think I was ever able to synch them correctly. I tore into the engine to put in new rings in hopes of solving the smoking issue but the pistons don't seem to have any blow by browning.
Also, on a different not, what is the springy rubber/plastic that keeps dust off of your forks called?
Thanks for any help!
Its hard to be wrong when you know nothing!
Offline kck3
Re: Valve Questions
« Reply #1 on: February 05, 2010, 11:43:38 PM »
1975 CB550
Also, on a different note, what is the springy rubber/plastic that keeps dust off of your forks called?
Fork Boot?
Offline domer
Re: Valve Questions
« Reply #2 on: February 06, 2010, 12:26:55 AM »
fork gator...
Re: Valve Questions
« Reply #3 on: February 06, 2010, 12:29:38 AM »
fork gaitors!!if the heads off,you should go the extra and disemble ,wire wheel and re seat them if theyre in good shape,new seals,its only half a job otherwise,do it once /do it well.
Offline kos
    • m3racing.com
Re: Valve Questions
« Reply #4 on: February 06, 2010, 05:33:23 AM »
And while it's off look at valve margins to see if there is recession? If so, order some up and replace, as there is no repair (ie: refacing) of worn Honda Valves due to hardness coating on valve sealing surface. In any case...what's the point of taking off head if you are not going to fix the problem?
KOS
220...221, whatever it takes.
Re: Valve Questions
« Reply #5 on: February 06, 2010, 07:28:40 AM »
KOS
Exactly
Offline campbmic
Re: Valve Questions
« Reply #6 on: February 06, 2010, 12:42:54 PM »
KOS
You have to take off the head to replace a piston ring
Also do these look like the correct fork boots?
http://cgi.ebay.com/ebaymotors/FR-FORK-BOOT-HONDA-CB200-CB250-CB350-CB360-CB450-CB550_W0QQitemZ140339710584QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item20ace60a78
Is there anything else I need to order to do a fork job? I've never worked on forks before but my gaitors were completely destroyed.
« Last Edit: February 06, 2010, 12:49:30 PM by campbmic »
