Author Topic: CB 175. Metal flakes, missing oil filter, and how do I get this out?  (Read 2114 times)
Offline fmctm1sw
I started the tear down my 175 after I found out 3rd gear was gone.  I got the motor out and was disassembling.  Couple findings...
The oil filter rotor:  If I would have looked at the manual first I would have known the cover was just pushed on.  Instead I tried to use a screwdriver on it and spin it (kind of like the way hubs are).  I broke off the remaining tab (someone already broke the other one) before I realized you just grab it with pliers and pop it off.  No real harm done, you can reach into it with a awl type tool and pull it off.
Once inside the filter rotor I found metal flakes.  No real surprise with the transmission acting up but isn't there supposed to be a filter in there?
The last worry is that bolt inside it.  Anyone have any ingenious ideas on getting it out?
Oh, and dig the weird scratches on the clutch housing...
« Last Edit: February 07, 2010, 02:51:15 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Kevin D
  • SE Michigan
Re: CB 175. Metal flakes, missing oil filter, and how do I get this out?
« Reply #1 on: February 07, 2010, 01:54:06 PM »
Its a centrifugal filter. No element inside. No need to take the cup off, just wipe/scrape out the crud.
That nut inside looks like the clutch hub nut on my 750. Fold the lock tab down and use special wrench to remove the nut. According to the parts fiche it is the same: 16mm.
I might be wrong about this but I think the CB750 might be the first production Honda to use a paper oil filter element.
« Last Edit: February 07, 2010, 02:05:07 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline crazypj
  • I'm brill, me
« Reply #2 on: February 07, 2010, 02:15:10 PM »
 I think you may be right  ;D
PJ
Offline fmctm1sw
« Reply #3 on: February 07, 2010, 02:50:59 PM »
Yeah I got to looking around after I posted that.  Just the pump screen.  I was able to fashion a tool to take the nut off (I hope).  I used a rotary tool to grind down a 7/8" socket.  I had to trim it a little after the photo but you get the picture.  Now I just have to find a way to keep the engine from rolling when I try to turn that nut.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline TomC
« Reply #4 on: February 07, 2010, 02:53:07 PM »
Hi fmctm1sw
     Looks like you are on the right track with your home made tool.
     Pro Motion sells the tool. I am told.
     If you know someone who has ridden a Honda Twin for some time and actually does regular maintenance they should have the tool. The cup is much easer to clean out of the engine.
     TomC in Ohio
« Last Edit: February 07, 2010, 02:57:00 PM by TomC »
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline fmctm1sw
« Reply #5 on: February 07, 2010, 02:57:06 PM »
Hi fmctm1sw
     TomC in Ohio
Thanks guys.  It's all coming out.  I have to split the cases to figure out what happened to the transmission...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline tbpmusic
« Reply #6 on: February 07, 2010, 03:23:49 PM »
Jam a penny between the gear behind the oil filter and the larger gear behind the clutch basket that it meshes with.
Bill Lane
