Author Topic: Has anyone replaced K0-K6 Triple Trees with a K7-K8 set?  (Read 1076 times)
Offline BigBoi
  • It's a jungle out there.
« on: February 08, 2010, 10:50:49 AM »
I'm in a bind here. Cracked my top bridge a while back and I'm having a hard time sourcing a bridge which is the same as mine. Will the trees for a K7-K8 fit my K2?
Re: Has anyone replaced K0-K6 Triple Trees with a K7-K8 set?
« Reply #1 on: February 08, 2010, 06:45:54 PM »
Yes, but they will kiss the tank.  look for a 77, if you want your brake junction to fit. You could build up your stops on the tree.
 If you want to slam, the tubes will slide up to the moon.. ;D
Offline doobiebro
« Reply #2 on: February 11, 2010, 10:45:42 AM »
You may have already found this, but if you use the '77 tree, be sure to use both the top and bottom sections.  Because of the change in offset in the '77 and '78 models from earlier models, you cannot use the K7 top with your K2 bottom.
Offline Toxic
« Reply #3 on: February 11, 2010, 12:07:32 PM »
Ya, I found this out the hard way. You can't mix and match.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #4 on: February 11, 2010, 01:58:12 PM »
I cracked - in fact broke off the corner of my top tree 3 months ago (K2). I couldn't source a replacement fast enough - so took it into a local auto machinist who had it welded - cost me about 50 of your dollars. Looks perfect.
Swoop
« Reply #5 on: February 11, 2010, 02:33:50 PM »
Hey Big Boi (jeez I sound like a $20 hooker  :o )....I should be getting another one next week......$50 US plus shipping if you want.
Steve
