Author Topic: clubmans, clip ons or euro bars...  (Read 8623 times)
Offline wannabridin
  • Patience made me a
  • -Garrett
« on: February 10, 2010, 06:21:15 AM »
hey guys.  i'm having some troubles deciding what bars i should run on my build.  i want to go with a cafe, and have it look as "vintage" as possible with some newer age things as well, so i don't know.
i currently have clubmans on there and while they look the part the best, they are a bit uncomfortable...  i've hear clip ons are a dang good alternative for comfort and performance, but they're expensive for the adjustable ones i've seen.  i saw some on here that had what looked like anodized gold fork clamps that were kind of hexagonal or octagonal in shape with good adjustments that were really simple.  i've also seen the tomaselli clip ons too, and they look pretty nice.
i also like the look of some lower rise super bike bars or super moto style bars.  i think the euro bars are kind of the same thing too?  well i was just wondering if you guys could post up some of your set ups and list the pros and cons of each.  i tried searching, but i couldn't find that one comparison i saw the other day between clubmans and clip ons...
thanks guys!!!
Offline Deltarider
Re: clubmans, clip ons or euro bars...
« Reply #1 on: February 10, 2010, 07:56:45 AM »
Honda's euro bars were much praised. They offer you that comfortable, slightly forward leaning position. So your bum does not have to carry all your weight and you can ride for hours on end. Best compromise IMO.
CB500K2-ED Excel black
Offline Old Scrambler
« Reply #2 on: February 10, 2010, 07:57:52 AM »
Your style should be consistent with your footpeg choice........flat or low-rise with standard pegs........adjustable clip-ons with set-back pegs and a low tank and seat. All components should be somewhat adjustable to allow for rider size.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline wannabridin
  • -Garrett
« Reply #3 on: February 10, 2010, 10:15:34 AM »
i'll be using rear sets from an FZR-600 i got a junkyard.  i will be welding some tabs onto the frame and possibly mounting a plate with adjustable holes on it in case i need to tweak the position.  otherwise, i'll mount a simple tab on there to keep things clean in a position i find comfortable.  not too aggressive, but something good.  i'm about 6'3 or so, 36" inseam.  I'll be running an earlier model supersport tank on there, the one with the flip up gas lid covering the filler hole.
so i think i have it narrowed down to clip ons or the euro type bars.  i'm going to be running this on a GL front end, which makes finding nice clip ons in the 37mm diameter a bit of a hassle...  does anyone have any specs on the euro bars?  maybe so i can compare them to a renthal or another aftermarket bar??
Offline ev0lve
« Reply #4 on: February 10, 2010, 12:27:09 PM »
Same boat so I'm interested to know what you decide - 6' 3", 36" inseam, GL1000 front end to swap.
I'm leaning in (ha) on the clipons and flattening out the top triple from the Goldwing. Currently running clubs on my bike and the clipons would raise the bars about 1.5 - 2 inches over their current position. If you're like me - monkey arms - it's not a stretch at all but a little rise would be nice.
The GL1000 top triple is pretty high so clubs might work pretty well but I really want to ditch the top triple and flatten out the profile so clipons are about the only choice.
Here's some links to what I'm looking at - not inexpensive but...
Tarrozi at Fast From the past - I think these are the ones
http://www.fastfromthepast.com/servlet/the-879/Clip-dsh-ons-37mm-offset%3D35mm/Detail
Not sure about these
http://www.fastfromthepast.com/servlet/the-727/Clip-dsh-on-Low-Rise-Handlebars/Detail
http://www.fastfromthepast.com/servlet/the-854/Clip-dsh-ons-37mm-offset%3D105mm/Detail
Vortex 37mm
Woodcraft
And eBay has a ton of em - no risers though.
Anyways, hope that's helpful and I'm really interested in what you decide.
Offline wannabridin
  • -Garrett
« Reply #5 on: February 10, 2010, 12:55:00 PM »
thanks iggy!!!  the ones i saw before aren't in the ones you posted, but i do like what you posted, good ideas!  it's hard to turn the clubmans down though, being that they were $15 and all!!  but they didn't feel to great on the wrists, and no i wasn't really stretched out, i'd just like a little more comfort on the wrists without sacrificing performance or looks!
looking at "Low Rise Clip-Ons" from Fast from the Past, I think i'm liking these more and more actually!
They can be adjusted quite a bit, i esp like the angled adjustment so i can fine tune my wrist orientation, and they sit higher than most standard clip ons.
« Last Edit: February 10, 2010, 12:58:39 PM by wannabridin »
Offline turboguzzi
« Reply #6 on: February 10, 2010, 01:16:16 PM »
I am 6'4" and I race with the raised Tarozzis, works pretty well on track , could be a bit of pain on the street.
That said, I dont have rear sets on any of my street bikes, hate them for everyday rides or touring.
Actually, I have made "fwd sets" on my two old school GSXR to be more comfy.
From my experience, at your height, you should not ever place the bars lower than the top of the triple clamp,( unless you are a masochist  :)
Offline ev0lve
« Reply #7 on: February 10, 2010, 01:28:39 PM »
Also, the forks will be up in the trees a bit - how much I don't know - so may be possible to run the clipons on top of the tree?
And if Turboguzzi says raised that's good enough for me  ;D
Offline grumpy
  • ..... '73 750K3 .....
« Reply #8 on: February 10, 2010, 01:39:01 PM »
Since you mentioned Supers - here's my setup.
More or less the same rise as Euros but with less back-sweep.
Offline turboguzzi
« Reply #9 on: February 10, 2010, 02:09:58 PM »
doubt it, you'd have to raise the forks by some 40mm, it'll lower the front too much and make the steering too twitchy.
niet
TG
Offline wannabridin
  • -Garrett
« Reply #10 on: February 10, 2010, 02:43:25 PM »
well damn, now i can't decide!  i like the super bike bars, and i know they're comfy, but how are they with rear sets?
Offline domer
« Reply #11 on: February 10, 2010, 02:55:35 PM »
these i call mystery bars, almost shaped like clubmans, but flat. no drop at all. fairly comfortable riding position i would compare to drag bars...
they arent reversed clubmans! they are flat!!!  ;D
Offline turboguzzi
« Reply #12 on: February 10, 2010, 02:57:16 PM »
feel your pain..... stock peg position is very fwd, so I would go at least with a mild rear set that puts the pegs more or less near the swingarm pivot. Those R6 might out your feet very far back,
before you weld anything try mounting them with some simple clamps/bolts and seat on the bike, see how they feel.
TG
Offline wannabridin
  • -Garrett
« Reply #13 on: February 10, 2010, 05:36:16 PM »
oh ya for sure!  i wouldn't put any welds on the frame without everything else being sorted out that needed to be!  well the rear sets are going to be pretty easy to make work the way i want by just making the mounts work...
Offline scunny
  • don't call me expert
« Reply #14 on: February 10, 2010, 08:06:20 PM »
euro bars for me
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline xfactor
« Reply #15 on: February 10, 2010, 08:58:44 PM »
euro bars for me
I really like those, who makes them?
Offline Deltarider
« Reply #16 on: February 11, 2010, 12:38:00 AM »
Honda.
Offline MickeyX
« Reply #17 on: February 11, 2010, 01:15:42 AM »
Or some Norman Hyde "M" bars... Kit just put these on her 350 and loves them.  :)
and here...
http://forums.sohc4.net/index.php?topic=53071.0
« Last Edit: February 11, 2010, 01:18:41 AM by MickeyX »
« Reply #18 on: February 11, 2010, 01:18:42 AM »
Super bike bars are the way to go, low enough to be sporty and you can ride hard with them and the most comfortable by a mile when compared to the other 2 you mention. I have ridden several 1000 mile days with the superbike bars and will always use them on my Hondas. Oh and i am also going to use them with rearsets with my build as well this time but the rearsets won't be as far back as they would be with clip ons..
« Reply #19 on: February 11, 2010, 05:06:14 AM »
More superbike bars...Im selling these ones ;-)
Superbike bars versus tomesselli bars:
Superike bars versus cheap euro bars...
The Honda euro bars Ill be trying next...or the Norman Hyde bars...
cheers
Andy
« Last Edit: February 11, 2010, 05:09:23 AM by andy750 »
Offline wannabridin
  • -Garrett
« Reply #20 on: February 11, 2010, 05:36:15 AM »
ahhh, the choices!!!  the decisions!!!!  man, tough choice.....
Offline Deltarider
« Reply #21 on: February 11, 2010, 07:29:25 AM »
Why don't you mount all three? So you can vary your riding position.  ;D I mean, I've seen guitars with two, two... how do you name it?
Offline grumpy
« Reply #22 on: February 11, 2010, 08:30:09 AM »
Necks  ;)
Offline Deltarider
« Reply #23 on: February 11, 2010, 08:40:51 AM »
Right, necks. Mount all three and you can be as proud as a man with three, three... how do you name it?
Offline wannabridin
  • -Garrett
« Reply #24 on: February 16, 2010, 08:13:42 AM »
i'm thinking of going with these:
anyone have experience with fast from the past?  also, anyone have experience with these bars or ones like them??
