Author Topic: Can't get my main jet to seat - HELP!  (Read 3975 times)
Offline theofam
  • I'm cold, give me a
  • Suffering from MDD - Mechanical Deficit Disorder
« on: February 12, 2010, 11:16:34 AM »
My main jet isn't seating properly such that when I put my leaf spring on, it just flops - no pressure to hold on the main jet.  The main jet seems to be sitting about 1/16" too high.  I've tried tapping the top of the jet with a hammer, but I'm worried too much pressure will cause damage.  I used WD40 to lube up the o-ring before install.
Stuck in the garage awaiting expertise!
Offline Little_Horse
    • My cafe build
Re: Can't get my main jet to seat - HELP!
« Reply #1 on: February 12, 2010, 12:09:55 PM »
I should have read this one first. The pressure to hold the jet in comes from the float bowl being screwed down. It should be loose in there, but the oring needs to be fully in. A sixteenth of an inch of jet should be out.
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
« Reply #2 on: February 12, 2010, 12:36:12 PM »
The oring for the jet met be contained withing the carb body casting feature.  I will often use grease to aid that feat.  The spring clip holds the jet in only when the bowls are installed.
The O ring must be soft enough to conform to any irregularities and create a proper seal.  Soft orings will hold the jet in place while the bowl is being installed.
The Main jet rests on the emulsion tube in the carb.  This is pushed out of the carb from the where the slide sits.  It needs cleaning if the rest of the carb needs cleaning.  It is often overlooked.
Offline theofam
« Reply #3 on: February 12, 2010, 02:33:02 PM »
Cornandp, thanks for the info on how the leaf spring works.  Makes sense.
Twotired, Ecosse told me if I rubbed my tank three times and said your name at some time you'd chime in!  It worked!  So, about this emulsion tube.  Sounds like I pull the main jet, get a small socket or punch in there and knock it out into the throat of the carb?  Is that right?  And yes, you're right, until you mentioned it, it was about to be overlooked, yet again.
Offline fmctm1sw
« Reply #4 on: February 12, 2010, 03:07:42 PM »
I've had good luck licking those main jets when they wouldn't go in the whole way.
Standing by for ridicule...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline theofam
« Reply #5 on: February 12, 2010, 03:15:46 PM »
fmctm1sw,  :D  Thanks for the good laugh!  That's usually how I clean my batteries!
Offline theofam
« Reply #6 on: February 12, 2010, 03:27:46 PM »
Twotired, never mind.  I got the emulsion tube out by dropping a punch in from the needle/slide/top and knocked it out.  It was clean, but who knows about the other three.
« Reply #7 on: February 12, 2010, 03:37:09 PM »
Glad you got the emulsion tube out.  Don't be too aggressive with the punch, though.  That's the end that has the needle jet orifice.  Distorting that would be...
...bad.
Offline Kframe
  • Life is good!
« Reply #8 on: February 12, 2010, 04:02:03 PM »
Oh crud I just read this about the emulsion tube.
I missed those when I cleaned my carbs last autumn.   :(
Bike seems to be running okay though, I haven't really run it around though as the tires are shot.  So I only have less than a hundred miles on it.
Well, come spring if she's running rough I know where to look first, so thanks!
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
« Reply #9 on: February 12, 2010, 04:12:09 PM »
The emulsion tube has cross drilled holes in it.  These are used to premix air (from an air jet) with the fuel making a froth, or emulsion.  The froth is far easier to draw/lift into the carb bore, which helps throttle response.  Further, if the holes are plugged, the fuel economy gets worse, as less air is in the fuel mix.
Offline theofam
« Reply #10 on: February 12, 2010, 10:05:31 PM »
TwoTired, I was very careful with the punch on the emulsion tube.  It took a very minor tap to get them out.
Kframe, you may be fine w/o doing the emulsion tubes.  Mine didn't have any gunk in them.  I've my fingers crossed for ya.
Offline Kframe
  • Life is good!
« Reply #11 on: February 13, 2010, 06:11:37 AM »
Thanks!
Now we just gotta wait for the snow to melt so I can ride more and find out for sure!
-K
1986 Honda Helix
