Author Topic: Backup generators for the home?  (Read 1398 times)
Offline Steve F
« on: February 14, 2010, 05:38:00 PM »
I've had a generator for over a decade, and have used it to run the house (most of it) when the power goes out.  At first, I was using several extension cords to plug in the essential things like the fridge, freezer, sump pump, but that got OLD really quick.  I have since installed a 30A outlet on the side of the house and back-feed through this.  BEFORE ALL YOU ELECTRICAL PEOPLE GET ALL OVER MY CASE, I'd like to say that I'm fully aware of the safety issue this presents to the utility workers, and make DAMN sure the main breaker is OFF FIRST!
  I've thought of getting a transfer switch, but those things **installed** are about $500!  I recently found a thing called an "interlock" that gets mounted on the breaker panel, and think I'm going to go that route so that I can feed the house through an outside connection to the panel and power the house that way.  Here's a link:  www.interlockkit.com  and think I could make something like this since even these things are $149 for my panel  :P
So, I'm wondering what other creative things have you all done or seen regarding disconnecting from the power grid in a safe manner?
Steve F
Offline boatsdickson
  • 1978 836 K8
Re: Backup generators for the home?
« Reply #1 on: February 16, 2010, 03:09:41 PM »
Glad you posted that steve. The wife and I just purchased our first generator for our country move in a few months. Moving to an all electric home was bothering me.
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline fmctm1sw
« Reply #2 on: February 18, 2010, 04:06:58 PM »
Power outages were an every day event in Guam when I was there.  I've seen a lot of what you did.  Guys would make a suicide plug and plug it into the dryer outlet and turn the main breaker off, leaving others on for stuff they wanted to power.  Every year you hear about someone running a generator in a garage or other poorly ventilated place though...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #3 on: February 18, 2010, 06:07:16 PM »
i've been thinking about a small diesel generator for our place. theres a concrete pad out back just for that, put in , in the early 60's my wife tells me
Mark Twain - Notebook, 1894
Offline mark
« Reply #4 on: February 18, 2010, 06:38:05 PM »
The interlock gadget looks like it would work.....
....also looks like a $19 gadget with a $130 'Approved' sticker to make the inspector happy.
nice of them to put pictures of all the different panels with lockout installed on their site though.
for identification.
F you mark...... F you.
Offline 333
  • Time for change
« Reply #5 on: February 18, 2010, 07:13:28 PM »
I'm not an "electrical guy", but there is no substitute for doing something the right way.  Sure, you know the risks, but what about when you're not around?  You can save some money by runnung the cable in from the generator yourself, as well as mounting the box, leaving the fina wiring to the pros.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mick7504
« Reply #6 on: February 18, 2010, 07:27:25 PM »
Power outages are common place here in Darwin especially in the tropical wet season.
We had a cyclone come through here a bit over a year ago which bought down some big African Mahogony trees across the HV power lines and we were without power for 3 days while this was being repaired.
What I did (and I'm not recommending this) is to cut the female plug off of an extension lead and wire on another male plug ending up with a lead and a male plug either end.
Switched the board off at the mains, plugged one end into the genset and the other into into a power outlet inside the house.
This ran the fans and the fridge and the lighting until we were back onto mains power again.
If I was you
I'd be worried about me.
Offline Alan F.
« Reply #7 on: February 18, 2010, 07:28:42 PM »
Not to go too far off topic, but it's a pretty popular mod to convert a backup generator to propane power since power output is close and engine life is increased, soot and carbon are reduced, propane may already be on site, it's cheaper and burns cleaner too.
Just a thought to consider.
Last winter the better part of the state of New Hampshire was without power for up to 4 weeks is some areas due to a heavy ice storm, lots of generators in service up there now.  In a pinch a car battery wired to a voltage inverter will supply some emergency power, when the battery begins to weaken just put it back in a vehicle and charge it back up.
« Last Edit: February 18, 2010, 07:33:11 PM by Alan F. »
Offline westondc
  • Wes Mantooth
« Reply #8 on: February 19, 2010, 06:25:05 AM »
My dad has done the same thing at our cabin. He bought a large gas powered generater and put it in our nice workshop/shed. he then went to the auto parts store and bought a muffler for a small car and adapted it to fit the generator and ran the exhaust out of the shop through a hole. now i don't know much about the exact specs but he installed a large outlet to the side of the breaker panel in the shed. we have a large gauge dual male ended plug that we can run from the generater to the outlet. when the power goes out we shut off the main breaker in the cabin and we can plug in the generater and run power back though the shed into the cabin. works great and I've had to go though this process a few times intoxicated at 2 am when we were having a few parties  ??? haven't blown up anything yet, but my dad did post a big yellow notice in the shed breaker to BE SURE TO SHUT OFF MAIN BREAKER BEFORE PLUGGING IN GENERATOR. i guess a $150 safety device would be worth it, cant imagine the cost and damage if the power came on with the generator running and the main breaker on....
on a side note my dad did come up with an interesting device that i noticed recently. since we installed propane heat, all we really need to power is the TV, fridge, and microwave when the power goes out... somuch for the use of that $800 generator. he took a battery backup from a computer and removed the internal battery, he then ran the battery wires to 3 or 4 small car batteries. this is plugged into the wall and a surge protector is plugged into the output from the backup power supply. we have the items we want to run plugged into the surge protector. worked like a charm the last time the power went out and we ran the TV and a few lights all night and the next day until the power went back on. now I'm no electrician but i thought this seemed a bit dangerous. my dads job involves electronics and wiring so I'm not going to second guess.
edit: now that i think of it, shouldnt the main breaker "pop" and prevent power from being fed back through the circut to the main line? remeber i said I'm no electrician...
« Last Edit: February 19, 2010, 06:34:44 AM by westondc »
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline Deceptibong
« Reply #9 on: February 19, 2010, 06:38:50 AM »
need more cabin parties!!!!!!! +BYOL (Bring your own ladies)
1972 CB750k2
Build / Travel Reports: http://easterntowestern.blogspot.com
Offline Steve F
« Reply #10 on: February 19, 2010, 06:41:53 AM »
The breaker cannot react fast enough to save your generator in this case.  It only take 1/2 of a cycle to do it's damage to the generator.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #11 on: February 19, 2010, 06:47:29 AM »
solar backup system.
http://www.mysolarbackup.com/
Offline westondc
  • Wes Mantooth
« Reply #12 on: February 19, 2010, 07:05:00 AM »
Hey Steve F, that safety switch in the first pic of yours looks pretty easy to fabricate. i might actually give it a shot the next time i make it out to my cabin. i mean it doesn't even have to be that elaborate. just one piece of tin with two bolts to allow it to slide back and forth would work.
« Last Edit: February 19, 2010, 07:06:48 AM by westondc »
1972 Honda CB500k1
1971 Honda CB350k3
Offline Steve F
« Reply #13 on: February 19, 2010, 09:39:11 AM »
Yes, that's about all it is.  I'm gonna give it a try too someday, but first I have to trace out the layout of the breakers to start designing one.
