Author Topic: Stuck center stand pivot pipe  (Read 1122 times)
Offline stueveone
« on: February 14, 2010, 08:19:00 PM »
Wow. My center stand pivot pipe was STUCK! After cracking that thing with a hammer and socket for about an hour. I let the ol PB Blaster work its magic (for about 5 days), but it's spells were rendered useless. So I took a drill ( a big mfing drill bit) and drilled out the center of the flange side and hogged it out until the pipe's walls were thin enough to take a chisel and screwdriver to fold the material inwards. That made it possible to clear the bolt mounting bracket and then the other side just pulled out. Holy hell!
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
Re: Stuck center stand pivot pipe
« Reply #1 on: February 14, 2010, 10:49:57 PM »
Did exactly the same as you. And it's  a rael pain.!!
Ash
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline fmctm1sw
« Reply #2 on: February 15, 2010, 04:52:12 AM »
I had one that was bent.  Same sort of struggle...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #3 on: February 15, 2010, 10:01:10 AM »
I cut the first one with a sawzall, then used a 1/2" all thread through it to hold it in place. I had the same struggle with the next one but the frame was naked and I wanted it original so I flipped it over and heated it with a torch. I inserted an allen head bolt that would fit through the bracket and drove the pivot tube out. Then de-rusted and greased.
