Author Topic: Honda middlePart # 292.??  (Read 7389 times)
« on: February 15, 2010, 07:03:22 PM »
 Anyone know what model its usually from ?
Re: Honda middlePart # 292.??
« Reply #1 on: February 15, 2010, 07:21:19 PM »
CB450
« Reply #2 on: February 15, 2010, 07:33:32 PM »
It is a tach or speedo cable....with large knurled end, & gray.
 I have several 450 parts books, with reverse numbers check. It did not show as being used in that bike series, even checked early book (single instrument) Nor did 292 appear to be  the dominant 450 number .
 I checked a few other books as well, but do not have the CB/CL 72/77 books
 If it is off 250 or 305 , I owe it to someone on here..
Part number is  44830-292-030... could be a revision..
Offline Kevin D
  • SE Michigan
« Reply #3 on: February 15, 2010, 07:39:26 PM »
« Last Edit: February 15, 2010, 07:45:15 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #4 on: February 15, 2010, 07:56:19 PM »
I will take another look at the cable tommorow, in case its mis labeled..
 That bike looks a bit newish for gray cables ... I know one end had a big knurled threaded end, but cant recall what the other end had..
 Thanks for all the help..
Offline TomC
« Reply #5 on: February 16, 2010, 06:46:54 AM »
Both 283 & 292 are 450 numbers.
 283 is the Black Bomber and 292 are first five speeds.
     TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
« Reply #6 on: February 16, 2010, 08:30:51 AM »
So does the 450 have a larger knurled fitting on engine end, than most tach nuts..?
Offline Kevin D
  • SE Michigan
« Reply #7 on: February 16, 2010, 01:21:52 PM »
 I found this useful list in the FAQ:
http://forums.sohc4.net/index.php?action=dlattach;topic=2894.0;attach=7560
And heres more than you want to know about Honda part numbers from Classic-Holland, including the fact that a 292 is indeed a CB450k1 code........mea culpa...... ::)
http://www.cmsnl.com/faq.php?fq_catid=14#14
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
« Reply #8 on: February 16, 2010, 08:36:42 PM »
 Here is what I found today;
 I picked another 450 book it had early models, and part # was in there..
 showed as speedo cable , NOT tach..
 Which I tend to believe, as
 cable from metal to metal end is just under 36 inches
 Large knurled ring,  and standard ring on speedo end, seems to jive with the early, seperate drive (not in hub)
 Anyway , nice greycable, looks NOS, minor shelfwear , it is...
