Author Topic: INITIAL START UP  (Read 1167 times)
Offline pinnacle
INITIAL START UP
« on: February 17, 2010, 12:39:18 PM »
HEY THERE GUYS SO I"M GETTING READY TO START UP A MOTOR I GOT FROM A SALVAGE YARD TO REPLACE THE ONE I HAD BLOWN BACK IN THE FALL.iT'S A MOTOR OFF 74 CB55O GOING ON A 78 FRAME AND WIRING.WHAT IS THE PROCEDURE FOR STARTING IT UP AS I AM A LITTLE NERVOUS OF POSSIBLY BLOWING THIS ONE AS WELL WHICH WOULD REALLY SCREW ME.I HAVE NOT TOUCHED ANYTHING OTHER THAN SWITCHING ROCKER COVERS,STATOR,AND CLEANING UP THE POINTS.
1974 cb550, 1978 cb550, 1984 honda shadow vt750
Re: INITIAL START UP
« Reply #1 on: February 17, 2010, 12:41:55 PM »
With the spark plugs out let the motor turn over for awhile to work some of that fresh oil you put in work its way around.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: February 17, 2010, 12:43:14 PM »
And pull a few tappet covers to look for signs of fresh oil up top.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline domer
« Reply #3 on: February 17, 2010, 02:43:54 PM »
but dont use electric start.... kick it slowly till you know the oil is pumping!
« Reply #4 on: February 17, 2010, 02:47:15 PM »
In addition put some Marvel or any thin oil for that matter down the plug holes and let it sit as long as you can. This way you are not getting a dry start.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: February 17, 2010, 02:49:48 PM »
pinnacle,
I think your caps lock key is broken.  ;) Just kidding, but all caps is not easy to read.
« Reply #6 on: February 17, 2010, 03:59:33 PM »
pinnacle,
I think some Seafoam on the keyboard will fix that up. ;)
Offline pinnacle
« Reply #7 on: February 17, 2010, 05:37:56 PM »
sorry about that guys i was using the computer at work and the caps has to be on for the adp program to work so i can log on to my next job.i work at a dodge dealership in the shop.anyways back to the original topic after installing the newer rocker cover off of the 78 cb550 i put a bit of oil down each tappet hole so that when i initially turned it over it was not dry and i have been kicking it over after putting fresh oil  and gas in it to get things somewhat going.just crossing my fingers i don't screw this one up.i did a dry compression test on it when i first got it and got descent compression since i don't know how long it was sitting out in the yard.it had no points cover on it so there was some rust that i cleaned up on the points and then i took the advancer and got the cob webs off and lubed her up so that after it was twisted it snapped back. i'm going outside and give the old girl a try and see what i get keeping my fingers crossed. just 1 lasst question though if i do get it running should i just let it run at an idle to allow parts to get back in to  working mode? how long should i wait before really throttling it up and seeing how things run at higher rpms?
Offline Alan F.
« Reply #8 on: February 17, 2010, 06:34:55 PM »
Once it's warmed up and you know you have oil flow to the valvetrain... gently rev it to 2 or 3 thousand rpm, I wouldn't rev it too much without riding it.
Did you have any luck?
-Alan
Offline CycleRanger
  • No comment about being an
« Reply #9 on: February 17, 2010, 07:04:56 PM »
If the motor was sitting for a long time you need change the oil filter and drop the pan and clean out the sludge and make sure the screen is clear before you start it.
Offline Alan F.
« Reply #10 on: February 17, 2010, 07:09:34 PM »
Good point there, does that engne have a chain oiler that you'd want to turn off too?
