Author Topic: andrews d grind and stock displacement?  (Read 2299 times)
Offline Zig
« on: February 18, 2010, 08:43:05 AM »
from the andrews web page, states is for 500/550/650 sohc4. was suggested to me specs may be for 750.
D grind, 19/45............244 degree............385 lift.
            45/19............244 degree............360 lift
I found this cam in a 900cc big bore engine i picked up.
Question is, how would it behave in a stock bore 750 with a stage 2 head, serdi valve job, stock valve train, stock carbs with pods and 4 into 1 exhst?
Opinions anyone?
Zig.
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
Re: andrews d grind and stock displacement?
« Reply #1 on: February 18, 2010, 02:30:04 PM »
I had one of these in an otherwise stock KO. Idle quality was OK, noticeable power boost about 6000 rpm.
I did not like the large valve clearances they recommended. I set the clearance at plus .002 over stock.
The cam is still good after 60,000 miles
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
