Author Topic: 78F CB750 Ignition switch wire placement  (Read 4849 times)
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« on: February 20, 2010, 02:24:37 PM »
Does anyone know, or have a 77 or 78F and would take a look at the order the wires should be in on the plug block for the ignition connector? I pulled mine off to replace the switch and the plug was so corroded it pulled right off at the wires. Now I don't know what wire goes where on the new plug I am trying to install.
There are 5 wires. Red, Black, Brown/White and two brown wires. Here is the switch layout...
      Top of switch
     Pin   Blank   Pin
     Pin    Pin     Pin
            Clip
     Bottom of switch
Can one of you guys fill in the colors for me by chance?
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
Offline michrobi
Re: 78F CB750 Ignition switch wire placement
« Reply #1 on: February 21, 2010, 09:01:09 AM »
Well, according to Clymer and my ohm meter it's wired correctly. My right turn signal only clicks the relay once, then nothing. Neither the front running light or the rear signal flash, and the dash right blink indicator is on solid until I turn on the right signal switch, then it dims the dash indicator slightly.
The left rear blinker works normally, but the front left isn't blinking. Horn, ignition, starter brake and park light all work properly. I guess I'll assume the ignition switch is wired correctly, and by coincidence the blinker wiring went to hell while I was re-wiring the switch block.
Electrical isn't my strong area.  ???
-Mike
Offline michrobi
« Reply #2 on: February 21, 2010, 09:28:53 AM »
Twas the headlight bucket bolt not being grounded that was messing with me. Thanks HondaMan.
-Mike
paulcrtny
« Reply #3 on: April 12, 2010, 09:57:19 AM »
dose anybody know which wires go where as i have the same problem
Offline shorterdanny
« Reply #4 on: April 12, 2010, 10:52:39 AM »
I'll have a look behind my switch tomorrow and let you know, if no one has done it before.
sorry can't do it earlier to help
good luck
1983 Honda CBX 750
1978 CB750 K7
Offline Rddmm2
« Reply #5 on: May 08, 2010, 03:11:02 PM »
On my 78cb750K, brown and br/white are dead - yet Red is powered to ignition and blk is hot when I turn on ignition.
NOTE: I recently replaced an old fairing and installed original headlight bucket and signals but I'm not sure why that would affect anything in the ignition switch.  I unplugged the round ignition switch and cleaned it up and seems in very good shape and cleaned up the rectangular 5 pin plug.  Is this an internal ignition switch problem?  is switch replacement the way to go?  what am I replacing exactly - just the round contact portion underneath?
Thanks.
Offline cgancos
    • Flickr Page
« Reply #6 on: June 15, 2010, 06:24:12 PM »
Could anyone hook me up with the colors? I'm guessing a 78 550 is the same. I just need to know which colors match which pins.
Thanks
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #7 on: June 15, 2010, 06:31:45 PM »
Thanks.
I noticed when i was replacing my ignition switch that the springs and contacts fall out really easy check and make sure they're all in there... and you can buy a jobber switch for about 15 bucks... at least you can here...
Thanks
If you can wait till fri night I'll look at my 78k and see exactly what wires go where and let you know
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
Offline cgancos
    • Flickr Page
« Reply #8 on: June 15, 2010, 06:45:10 PM »
That'd be great!
Offline cgancos
    • Flickr Page
« Reply #9 on: June 19, 2010, 02:39:47 PM »
Could anyone help me with this?
Offline axehole54
  • #169 North
« Reply #10 on: June 20, 2010, 09:40:16 AM »
Sorry for the delay i'll blame beer and bbq. The  correct order is  on my switch:            brown    blank  brown/white      black       red         brown
Offline cgancos
    • Flickr Page
« Reply #11 on: June 20, 2010, 10:08:01 AM »
Awesome, I really do appreciate it.
Offline axehole54
  • #169 North
« Reply #12 on: June 20, 2010, 10:24:52 AM »
No problem hope everything works for you
