Author Topic: tech support help needed--no spark  (Read 905 times)
SmokeRider
« on: February 21, 2010, 07:28:33 AM »
Hi  again I just started to work though this 400f. I had an old battery that I charged overnignt but the volts only came up to 9.6V. I placed it in the bike and got a slight green glow at the gear selector indicator-- gave it a few kicks and no spark at the plugs (grounded to the motor) I pulled the stator cover and points cover off first and no rust and everything looks in order. Do I need a fully charged batt. to generate spark at the plugs? Also any other ideas- how do you guys sort out no spark issues. thanks for your help and input regards
fastfred
Re: tech support help needed--no spark
« Reply #1 on: February 21, 2010, 08:16:17 AM »
9.6 volts after an all all night charge tells you that you have a battery that is knackered. Even 11 volts is not good.
A good charging system might give a brief spark via the battery to the plugs but you do need a new battery regardless.
Regards
SmokeRider
« Reply #2 on: February 21, 2010, 03:26:00 PM »
this may be a stupid question, do you need the battery to make spark?
Offline fmctm1sw
« Reply #3 on: February 21, 2010, 03:40:31 PM »
yes...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline davesee
« Reply #4 on: February 21, 2010, 03:54:13 PM »
you can check spark using your car battery. don't follow the procedure for normal car jumping! just disconnect the motorcycle battery (and might as well take it out and use it as a door stop), disconnect the car battery from the car ( i take mine out) and then connect it to your bike with jumpers. that should allow you to test for spark. good luck.
by the way, your bike looks cool.
1980 honda cb650 with many weekends worth of modifications.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #5 on: February 21, 2010, 04:04:44 PM »
Whenever you connect a battery (car or M/C), double, even triple check that you are connecting POS 2 POS  and NEG to ground.  Hooking up a battery backwards will fry many sensitive components!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
SmokeRider
« Reply #6 on: February 22, 2010, 04:29:38 PM »
ok thanks.
« Reply #7 on: February 22, 2010, 04:32:57 PM »
Yes, you need a good battery.  The bikes alternator makes no power without the electromagnet excited.  Doesn't matter how hard you spin it.
No electrical power, no spark.
