Author Topic: Headlamp Upgrade - '76 CB400F  (Read 4044 times)
nobrakes
« on: January 12, 2006, 12:09:21 PM »
Looking to upgrade headlamp to a halogen bulb and am wondering if anyone out there has any suggestions.  The Cibie halogen lamp/bucket comes with a higher watt bulb that'll drain the battery and the fix is to downgrade to a 35w bulb, but I wanted to see if anyone has found a light upgrade that doesn't require modifying the bulb and will just bolt right on.
Thanks!
Scott
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: Headlamp Upgrade - '76 CB400F
« Reply #1 on: January 12, 2006, 12:29:06 PM »
I don't know what brand mine is, but there's a big "H4" stamped on the lens.  I'm running a standard 55/60 watt lamp with no problem, and normallykeep it set on high-beam.  I also added two 'Autozone-special' incandescent indicator lights to the back end (taillight blew out at night, never again riding with a dark rear end).
I thought these came with a standard 55 watt lamp.  Incandescent or halogen, 55 watts is 55 watts.  I believe you just get more light for the power.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
gaijin
« Reply #2 on: January 13, 2006, 02:17:57 AM »
I actually just bought one.  I got the 8022 lamp from Candlepower Inc and a 45/45 watt high-efficiency bulb. I was going to get a 35/35 but decided to try the other one.
 About it: It's nice. Bolts right on. I managed to fit it onto my old headlamp ring even though the previous owner had bent it to fit a 6" car headlamp into it. There's a small 1/4 inch gap between the front of the new lamp housing and the headlamp ring because the halogen lamp is flat, not curved. Some people have used foam tape to seal the gap with good results.. The lens adjuster will still work though the captive nut doesn't seem to be as captive as it was. I've had trouble aiming the lamp down far enough, but I think that's a separate issue. Maybe not, but fixable. A Cibie would probably be a little nicer, but this is pretty inexpensive. The bulbs it takes are the standard H4 format.
Purchase info: (NOTE: He doesn't answer the other number much, here's a direct line. I think. 416-766-2327)
This was posted on the yahoocb400f messageboard.
Hey folks,
After reading Fred's post about Halogen headlights, I got in
contact
with Candle Power and asked them if they still made the H4 conversion
that Fred had used. It appears they do and better still, they make a
"12 Volt, 35/35 Watt bulb for bikes equipped with
low-capacity generators and batteries."
What do you guys think? See below.
Matthew
Greetings, Mr. Dishner. You write:
> I began restoring/refitting a CB400F about a year ago and I have run
> into a brick wall of sorts. I cannot find a halogen headlight that
> will fit the 6 3/8" stock bucket.
Our 8022 round motorcycle headlamp has a nominal lens diameter of 6
3/8", or 162mm. It is equipped with a patented multi-bracket that
enables it to fit and work correctly in place of a great many original
headlamps (both sealed beam and replaceable bulb type) found primarily
on Japanese-made 350s and 400s of the late 1960s through 1980s.
The 8022 lamp is $35.95 without bulb.
With the 8022 lamp, there are different bulbs from which to choose:
12-VOLT, 60/55-WATT BULBS:
Standard 4720: Regular normal H4 bulb. $6.99/ea
Long-life 4720LL: Standard light output with extended lifespan.
$8.99/ea
Heavy-duty 4720HD: Has a vibration-resistant filament for use in
high-vibration service $9.99/ea
Bright Light Blue 4720BLB: daylight-white light color $14.99/ea
All Weather 4720AW: Yellow-tinted light that still counts as "white".
$14.99/ea
Gold 4720G: Strong yellow-colored light. $12.99/ea
High-Efficiency 4720BL: 30% more light at beam "hot spot" $11.99/ea
Super High Efficiency 4720SBL: 50% more light at beam "hot spot"
$15.99/ea
SPECIAL-SERVICE BULBS:
A 12 Volt, 35/35 Watt bulb can be furnished for bikes equipped with
low-capacity generators and batteries. This bulb is $6.99.
A 6 Volt, 60/55 Watt bulb can be furnished for bikes equipped with 6
Volt electrical systems. This bulb is $8.99.
Shipping to the lower 48 states with up to five bulbs will run $9.99.
ORDERING INSTRUCTIONS
We accept Visa and Mastercard.
Please indicate:
The quantity of each item you wish
The type of shipping you wish (UPS trackable ground shipping is
standard;
all UPS service levels are available)
The address to which you want the items shipped (if different from
billing
address)
Whether the UPS driver has permission to leave the parcel at your
doorstep
if you are not available to accept it in person.
NEW! Toll-free ordering!
You may now phone-in or fax-in your order toll-free on 1-866-861-8668
Whatever method you use, the following information is required in
order
to
process a credit card order:
Card type
Card number
Expiry date
Your name as it appears on the card
Billing address
Please don't forget to include a note (such as a printout of our
e-mail)
stating exactly which items you are ordering, and where you wish them
sent.
We look forward to meeting your lighting needs quickly and
efficiently!
Daniel Stern
"Candlepower, Inc.
« Last Edit: January 13, 2006, 02:22:29 AM by gaijin »
Offline Tim2005
« Reply #3 on: January 13, 2006, 11:15:12 AM »
I also use an H4 60/55 in a cibie in my 400/4, I do lots of town riding in winter so remove the bulbs from the speedo and tacho, 4  x 5w = 20w... problems solved!
nobrakes
« Reply #4 on: January 13, 2006, 12:57:30 PM »
Thanks for the info all!  I think the Cibie is the way to go (although expensive...) since a piece of the headlamp bucket cracked recently when putting new bars on the bike.  Looks like I'd still have to locate a new bucket if I went with Candlepower Inc.
Scott
