Author Topic: CR rep. rev counter?  (Read 3213 times)
Offline Phil
« on: February 23, 2010, 11:15:22 am »
I need a rev counter to fit the CR750 bracket. I know these are like gold (but I would pay...) but has anyone experience of having a mechanical Veglia 're-faced' to look like the original CR750 kit rev-counter? Veglia make one that works and I know a guy who says he can make a face but he needs a good photo of the original - can anybody help? I bought a Smiths unit complete with original rubber-band mounting that fits perfectly but it is only 2.5 inch diameter and doesn't look right! Honda must have copied the Smiths rubber mounting which pre-dates the ND by years!)
Offline lordmoonpie
    • Moonpie
Re: CR rep. rev counter?
« Reply #1 on: February 23, 2010, 12:17:00 pm »
Phil, trawl the Daytona CR750 thread, Kos, Eric and Sam were having a debate about clocks a few pages back and there were posts of the correct tachos and oil gauges. Failing that I can photograph mine but in true Spinal Tap style, mine goes all the way to 14,000  :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline Ricky_Racer
« Reply #2 on: February 23, 2010, 01:52:22 pm »
I'll trade you Nikon (large) photos of the 12K ND for a photo and paper tracing of the original tach/oil pressure CR750 mount!  ;)  RR
Offline lordmoonpie
    • Moonpie
« Reply #3 on: February 24, 2010, 01:23:32 am »
RR - I've got the original oil/tacho mount plans - PM me your email and I'll scan it for you...
1994 Ducati 888 SP5
Offline Phil
« Reply #4 on: February 24, 2010, 02:34:40 am »
I got mine from Carsten: http://www.tr4-rally.com/cr750.html - it seems fine, nicely made and perfect fit.
  • Moderator
« Reply #5 on: February 24, 2010, 03:18:25 am »
Looks about parr for the coarse, how many million euros was that ?  :D :D :D :D :D
Sam. ;)
Offline Phil
« Reply #6 on: February 24, 2010, 03:50:18 am »
150 euros - not bad?
Offline lordmoonpie
    • Moonpie
« Reply #7 on: February 24, 2010, 06:21:20 am »
I got my brake unioin from Carsten - sent it back three times before I gave up, they all leaked through the porous casting once the brakes were bled up to a reasonable pressure....shame.
1994 Ducati 888 SP5
Offline kos
    • m3racing.com
« Reply #8 on: February 24, 2010, 09:12:31 am »
Casting...WTF? Needs to be carved from billet. A solid junk of good alloy. And why does one want to add another junction in a brake set up? One should run the brake lines directly from master cylinder on handle bar to calipers on fork legs. If it is an appearance thing...who cares...probably not going to ride it anyway.
KOS
220...221, whatever it takes.
Offline lordmoonpie
    • Moonpie
« Reply #9 on: February 25, 2010, 02:01:28 am »
I was amazed to say the least - it oozed brake fluid like a rotting sore! I went with an earls splitter for looks and it allows a good pump but not as good as the single lines on my 450 so once I've finished parading/showing the 750, I'm converting to two independent lines.
1994 Ducati 888 SP5
Offline Phil
« Reply #10 on: March 02, 2010, 11:39:05 am »
RE the rev-counter. Thanks for the great pics of the CR750 kit rev-counter. I have ordered a Veglia and a chap is going to make an ND replica face for it! I will let you know how it goes!
Offline lordmoonpie
    • Moonpie
« Reply #11 on: March 03, 2010, 02:16:59 am »
Phil - who you using to make the new face? Worth knowing for future reference...
1994 Ducati 888 SP5
  • Moderator
« Reply #12 on: March 03, 2010, 03:43:21 am »
Would be good if you got hold of a copy before he fits it.
Sam.
