Author Topic: Custom exhaust clamps for Spigot mount 750s  (Read 4531 times)
« on: February 25, 2010, 08:27:08 PM »
I am working on a lighter cleaner looking clamp for  750s. Used to be  a steel chromed one like this years ago. I think Ness made them..
 Anyway it will be a smooth band that goes around the pipe, with a thicker area, that is slit and has an Allen head pinch bolt.
 Stock weighs 187 grams, this is at 74, but I am taking more off it yet.
 Anyway, should have one ready for pics tommorow nite..
Offline Ricky_Racer
Re: Custom exhaust clamps for Spigot mount 750s
« Reply #1 on: February 25, 2010, 08:32:08 PM »
Cool! RR
Offline 1080
« Reply #2 on: February 26, 2010, 06:35:28 PM »
Exhaust clamp for any 750 Spigot mount engine.
754 will provide more information.
My RC motor is NOT for sale. ;D
Offline Ricky_Racer
« Reply #3 on: February 26, 2010, 07:02:17 PM »
Ooouuuu! I like 'em!   :o   RR
« Reply #4 on: February 27, 2010, 09:25:33 AM »
That is first prototype,  guess how I cut the outer part of the band, on the non clamping area?
I will probably thin the band area, by quite a bit, and maybe radius the outer edge (more work).. but that would make em look lighter..67 gr from 187.. they will be lighter than that.. ;D
 With these installed, you can remove a 4-1 header in 3 minutes or less, dont need to remove claps and they wont gurf the frame (or require removing the  clamps)like the stock ones do when removing pipes..
« Last Edit: February 27, 2010, 09:32:19 AM by 754 »
« Reply #5 on: February 27, 2010, 10:09:34 AM »
I see CycleX has these steel ones for around 20 bucks a set. Pretty Fugly though compared to your pretty billet style units.
« Reply #6 on: February 27, 2010, 01:57:11 PM »
I'm guessing rotary table on a mill. What do I win if I'm right??? ;)
Here is a pic of the clamps I made, using .100 wall tubing. No idea how much they weigh, but I was going for as light as possible.
« Last Edit: February 27, 2010, 02:01:55 PM by scottly »
DaveL
« Reply #7 on: February 27, 2010, 04:52:33 PM »
Looks like bandsaw to me.
« Reply #8 on: February 27, 2010, 05:58:41 PM »
Nope & nope..
The clamp portion was done on a mill, no rotary table used on the piece at all..
« Reply #9 on: February 27, 2010, 06:11:08 PM »
If you mean you did this on a hand cranked mill, rather than CNC, I bow to your machining skills, sir.
« Reply #10 on: February 27, 2010, 06:15:54 PM »
The outer part of the band portion, (not the clamping part) was done on a machine tool without the motor running..
 At least 4 machines come to mind that could do this..
« Reply #11 on: February 27, 2010, 06:23:25 PM »
OK, you've really got me curious; you say a mill, then a machine tool without the motor running??? However you did it, it is much prettier than mine.
« Reply #12 on: February 27, 2010, 06:28:40 PM »
Ok, did you do the outer part in a lathe, turning the chuck by hand???
« Reply #13 on: February 27, 2010, 06:44:50 PM »
The linear marks are making me think you "broached" the OD with lateral stokes of the carriage, slightly rotating the chuck between strokes, ala shaper??? (still in a lathe)
« Reply #14 on: February 27, 2010, 06:59:06 PM »
Yup, exactly... the shaper method on the lathe..very observant.. :o.. I thought the tool marks would make someone think water jet or laser..
 I have a small shaper, it is tucked away right now.. they are really fun to use. If you locked the spindle (from turning) you could use a milll or a drill, be easier than the lathe, also can be done on shaper, slotter, slotting attackment on mill.
 I did not clamp it in the lathe, I slipped it on a mandrel, then turned the chuck.
 I did this for a few reasons, mainly to ilustrate that you could actually make parts yourself with little equipment, ie a triple tree with a lathe and a drill press..
« Reply #15 on: February 27, 2010, 07:04:36 PM »
Brilliant, tho labor intensive. What are the other three machines that could have been used?
« Reply #16 on: February 27, 2010, 07:14:52 PM »
Re-read your previous post; disregard the question about the other three machines.
« Reply #17 on: March 21, 2010, 02:35:30 PM »
I will start building these soon.
 I will probably thin the band area, or mill a lot of the middle of the band out... just change the looks a bit.
« Reply #18 on: November 22, 2011, 07:39:24 AM »
 I am working on a cleaner looking clamp will have a few sets ready in a week..
 pics will be posted soon..
« Reply #19 on: November 22, 2011, 07:59:29 AM »
Inventive!  I use my lathe to cut key groves on various parts, the only thing is it feels pretty abusive for the small Logan.
What was the size of the raw piece before you started?  I will have to make some clamps myself soon.
Offline 1080
« Reply #20 on: November 23, 2011, 10:03:19 PM »
Some up date photo's of what 754 is making, check out  his triple tree.
« Last Edit: November 23, 2011, 10:04:53 PM by 1080 »
« Reply #21 on: November 23, 2011, 10:09:09 PM »
Nice work Frank..... ;)
« Reply #22 on: November 24, 2011, 10:37:14 AM »
 Thanks.
 I cant turn this into a DIY thread, its my income (hopefully, you will under stand)
 The smooth clamp is the original prototype, which did not quite do it for me.The grooved ones is what I will be selling soon, they are a few steps from finished in the photos. May make a few smooth ones as well.
 I will have three sets ready in the next few days, first set is spoken for.
 The addition of the groove is more work, but makes it lighter, better looking and cools off quicker..
 Thanks 1080 for posting the pics.
« Reply #23 on: November 24, 2011, 03:00:57 PM »
How about exhaust clamp with two bolts?  You can install those w/o taking off the exhaust.
« Reply #24 on: December 08, 2011, 11:00:44 AM »
 I got two sets of these left at 100 bux plus shipping. not sure I will make any more soon, a bit labor-intensive. Should be a pic up soon of a finished set on a motor..
