Author Topic: Clear Coat Question  (Read 1240 times)
Offline Calflash
Clear Coat Question
« on: February 27, 2010, 07:58:00 AM »
I want a "semi gloss" finish on my tank and fender. Can I use this "SprayMax Urethane Aerosol Clear Coat"  or do I need to find a "semi gloss" clear coat?
Calflash
US Army
Nam 66-67
80 CB650
Re: Clear Coat Question
« Reply #1 on: February 27, 2010, 08:28:02 AM »
I would guess that unless it is labeled as a semigloss than it would be gloss as is most "clear coat". Hopefully gas and alcohol (no not whiskey :D) resistant.
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: February 27, 2010, 09:49:15 PM »
Calflash,
You have to use a 2-part clear if you want it to last.  You will also need to sand away to bare metal around the lip of the fuel filler cap, and where your petcock goes on.  If you don't, then fuel will get under the edge and lift the paint up.
The 2-part clear is the only clear in a can that will hold up to gasoline.  The others just plain and simple will not hold up.  It is only $20 for a can of the spraymax, which is money well spent the first time you dribble some gas on your new paint job.
Good luck and post some pics when done.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Calflash
« Reply #3 on: February 28, 2010, 02:28:58 AM »
Thanks for the advice. I'll post some pic's when the bike is finished.
Calflash
US Army
Nam 66-67
80 CB650
Offline faux fiddy
  • bike in a box
« Reply #4 on: February 28, 2010, 03:10:31 AM »
Gloss clearcoat + 1000 grit wet-dry sandpaper + a few hours of elbow grease = semigloss
You can probably even get away with using 600 grit.
Using even finer grit and polish can bring it back to glossy.
A friend of  mine  does it as an option on imported pianos for sale at his dad's store.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline UK Pete
« Reply #5 on: February 28, 2010, 03:29:55 AM »
Watch out lots of 2k paints still get damaged by petrol, even when they have been oven cured
pete
Offline Calflash
« Reply #6 on: March 01, 2010, 04:46:43 AM »
Will spraymax resist gas?
Calflash
US Army
Nam 66-67
80 CB650
