Author Topic: Field and Stator coil question  (Read 8304 times)
Offline NickC
« on: February 27, 2010, 09:32:20 PM »
1975 CB550k
What would cause both to go bad? I've had a charging problem since my rebuild. Regulator, good. Rectifier, good. Tested the  2 wires on the field coil- 0.00ohms. Damn, moved over to the Stator coil. All 3 yellow wires, 0.00 ohms. What causes these things to go bad? This bike only has about 18k on it, but has seen somewhat of a rough life.
Re: Field and Stator coil question
« Reply #1 on: February 28, 2010, 01:32:11 AM »
The stator windings are normally 0.35 Ω +/- 10%.  What did you expect?
What is the accuracy of your test equipment?
The simple fact that all your readings indicate 0.00, makes me question either test equipment or test technique.
But...
What would make them both go to a true 0.00 Ω ?   Mechanical mayhem.  Sledge hammer, blunt force trauma.  A really hot fire, like a smelting furnace. Localized interruptions in physical laws (perhaps from an alternate universe).  A vivid imagination.  Or, the introduction of mind altering substances making those readings seem real.
But, I'm just guessing.... ;D
Offline Hush
« Reply #2 on: February 28, 2010, 01:39:03 AM »
I'm with TT on the way you may have tested your components, however being one of those replace and see guys (as testing bores me to death) find another rotor and put it in, worked for a few 650's I know of. ;)
Do 550's have rotors?
Anyhow the standard test for those large hunks of metal are not accurate and often show a rotor to be good when usefull only as a doorstop......replace.....get back riding. ;D
« Reply #3 on: February 28, 2010, 01:44:40 AM »
digital multimeter?touch the probes together and you should get a reading if the meter is ok,if theyre gone theyre gone.,clean connections as you test?is it on the correct setting ,ie not volts or amps?
Offline NickC
« Reply #4 on: February 28, 2010, 09:59:21 AM »
I'm using a brand new fluke multi-meter. Yes, I'm using it correctly. Done some other checks, and even compared it to my old fluke with the same results.
Testing the field coil- Check resistance between both wires
Testing the Stator- check resistance between all 3 yellow wires.
This is correct, no?
« Reply #5 on: February 28, 2010, 11:10:04 AM »
What is the scale reading when you touch the probe tips together?  (Wires, have resistance, too.)
Can you make any resistance measurements (anywhere) to show the meter is capable giving a non-zero indication?
It is really only more expensive, purpose built, ohmmeters that have the capability to measure 0.35 ohms with reliable accuracy.
The upshot is that we have doubts as to the accuracy of the numbers you've reported.
However, if you trust the measurements you've relayed, then go ahead and replace all those components.
You might want to describe where, exactly, you are placing the probe tips for those measurements.  All the measurements are intended to be taken on specimens disconnected from the bike's wire harness, of course.
Offline NickC
« Reply #6 on: February 28, 2010, 11:53:36 AM »
Ok, broke out my Ideal meter. Got about ~.08 touching the probes.
Field coil came out to 5.0 -standard resistance is 4.9+/- 10%........ good to go
Stator coil came to 1.5  -standard resistance is .35 +/- 10%......why so high?
« Reply #7 on: February 28, 2010, 11:59:54 AM »
You should also take readings to verify there is NO continuity from any of the leads to ground, both the field and the stator.
« Reply #8 on: February 28, 2010, 12:09:14 PM »
Probably test technique.  There is small resistance between probe tip and tested device contact, and it adds up. What reading do you get when both probe tips make contact either side of a single stator terminal?  Notice how that changes with the probe tip contact pressure applied?  You are poking through a resistive film on the contact.  Pointier probe tips can help pierce the film.
Now you know why terminals need to be cleaned and protected from atmospheric corrosive elements.
Offline Spanner 1
« Reply #9 on: February 28, 2010, 03:04:56 PM »
Nick, the first test of your charging system should be the old ' voltage-vs.-r.p.m. ' test..... just connect your voltage meter across the battery and note the voltage, then turn ign. 'on' and start the bike...then see if the voltage rises with increasing r.p.m. up to a max of about 14.5v @ say, 5,000 rpm............ have ya tried that ?
Offline Hondell
  • Just an easy 1000 Hr. resto
« Reply #10 on: March 01, 2010, 08:06:18 AM »
Unless your Fluke is a four wire ohmmeter you will NOT measure low resistance accurately.
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline NickC
« Reply #11 on: March 01, 2010, 09:57:32 AM »
Haven't been able to do that yet, had to change over to a working tach. That will be the first thing I do whenever it's back together
Offline NickC
« Reply #12 on: March 03, 2010, 06:07:00 PM »
Damn, with a charged battery, I'm only getting 12.5, occasionally jumping up to 12.9, and down as low as 12.2
« Reply #13 on: March 03, 2010, 06:19:29 PM »
Hey, it's doing something if it's getting to 12.9V! It takes time to get up there to 14V, especially if you are using electric start. You've got to replace the big amps the starter takes.
Offline Spanner 1
« Reply #14 on: March 03, 2010, 06:34:15 PM »
With a fresh charged battery the alt. would not kick-in until the voltage drops below say 12v... so +1 with Scottly you would not expect to see 14.5 v ..... let the headlight run ( bike not running ) until the voltage drops to say 11.5v, then start it and see if the voltage rises to 14.5v @ 5,000 rpm.
Offline NickC
« Reply #15 on: March 03, 2010, 06:46:34 PM »
From my manual:
"When the battery voltage is lower than normal (less than 13.5V at the battery terminal), the current flows through the upper contact and to the field coil....when the battery terminal voltage is 12V, the field coil current is 1.6A....raises to 14v.....lowers to 0.7A"
« Reply #16 on: March 03, 2010, 06:50:32 PM »
It only rises to 14V After it supplies the demand of the battery, while also supplying the needs of the lights and ignition.
Offline NickC
« Reply #17 on: March 03, 2010, 06:59:25 PM »
Just out of curiosity, I pulled the lighting fuses and set it at 5k, averaging 12.9, bouncing as low as 12.2
« Reply #18 on: March 03, 2010, 07:01:17 PM »
Bouncing while holding a steady RPM??
Offline NickC
« Reply #19 on: March 03, 2010, 07:13:42 PM »
Yes, about a volt. It swings from 12.3 to 12.9, but averages in the upper range.
« Reply #20 on: March 03, 2010, 07:21:09 PM »
Should be steady (digital meter? not prone to vibration). Start looking for loose connections, like main chassis grounds, might also be a regulator problem. Just guessing...
« Reply #21 on: March 03, 2010, 09:16:54 PM »
Nick, let's get back to the basics, tomorrow. There are some questions I'd like to ask you.
Scott
Offline NickC
« Reply #22 on: March 03, 2010, 09:29:54 PM »
I'm going to jump the voltage reg tomorrow, and go from there.
« Reply #23 on: March 03, 2010, 09:33:50 PM »
Hey, do what you want. If it was me, I would take some measurements first....
Offline NickC
« Reply #24 on: March 03, 2010, 09:50:17 PM »
I tested my regulator, opened it up, checked the point gap, and the core gap. I just want to perform the "lets see what happens" trick  :D
