Author Topic: Shaving handle bar mounts off of triple tree? Possible? How?  (Read 11835 times)
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« on: February 28, 2010, 04:55:19 PM »
So I've had clip-ons for a couple of years and I love them.... but i don't love the ugliness of the handlebarless triple tree.... I have a spare and I'm wondering if its possible, and safe, to shave off the old handle bar mounts. Also if anyone has done it, how?
Thanks
Offline Alan F.
Re: Shaving handle bar mounts off of triple tree? Possible? How?
« Reply #1 on: February 28, 2010, 05:54:03 PM »
It's possible to mill off the handlebar clamps, but the casting is, for lack of a better word...hollow.  Concave on the underside.  Have a look at your spare and you'll see just what I mean, if you mill the clamps off, you'll cut right through leaving an open hole.
The upside is that there's a simple and inexpensive solution if it fits your tastes.
Mount the upper tree upside down.
Then paint or polish it.
-Alan
Offline jon®2004
« Reply #2 on: February 28, 2010, 06:32:21 PM »
I first cut the tabs off, then had the holes filled with weld. After some grinding (lot of it) and sanding they are smooth. Looks real good. It's possible but it takes some work.
jon®
Offline BlindJoe
« Reply #3 on: February 28, 2010, 06:34:13 PM »
if you do it right you can make the holes look good.
  • Be careful you might get a
« Reply #4 on: February 28, 2010, 07:34:05 PM »
Here's how my 400f triple looks now that I've shaved the clamps off and buffed it out.
Offline BlindJoe
« Reply #5 on: February 28, 2010, 07:34:47 PM »
like i was saying  ;D
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #6 on: February 28, 2010, 08:41:26 PM »
WOW!!! That looks spectacular!!!! Even with the holes left in it.....
That is exactly what I'm talking about.... So I'm convinced.... and even though I'm not the best at metal work I'm going for it. Thanks for all your thoughts on this.... This site is the BEES KNEES!
Offline plastikjock
« Reply #7 on: March 01, 2010, 04:18:53 AM »
Had mine welded from the rear 1st before chopping and smoothing. If you look closely there are two minor voids in one side, at some stage I will grind these out and fill with weld.
Offline Laminar
  • Retsam
« Reply #8 on: March 01, 2010, 06:31:30 AM »
These pictures are taken from cornandp's 550 cafe build.
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #9 on: March 01, 2010, 06:55:05 AM »
Now that's freaking cool, intelligent use of the holes even. Maybe I'll grab a spare tree and have the option to do something similar.
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #10 on: March 01, 2010, 08:48:34 AM »
i used a 1/2" end mill to cut mine off. it's tricky getting a bandsaw very far down the post, so you end up have to remove some material otherwise, even if you start there.
« Last Edit: March 02, 2010, 12:35:49 AM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #11 on: March 01, 2010, 09:36:38 AM »
This is for my CR750 build.
Machined down, welded up and smoothed before painting with 2K gloss black.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #12 on: March 01, 2010, 09:39:36 AM »
I just cut them off with a cutting wheel, then ground down what was left.
No.
Offline jakecb420
« Reply #13 on: March 01, 2010, 06:43:08 PM »
my wife thinks that pauls triple tree is a freakin cool idea. so do i
750K3 daily driver
76 750F project
74 CB450 donor
79 50cc honda express 2 moped
73 cb500-4
http://forums.sohc4.net/index.php?topic=73724.0
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #14 on: March 02, 2010, 02:51:04 PM »
Thanks for all the picks and posts... I'm really liking the polished look with the wholes.... gonna get started this weekend and I'll try to post some picks when I'm done. ;D
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #15 on: April 18, 2010, 03:32:49 PM »
well... here are some process picks and the final results... i used and angle grinder with cutting and flap disks for smoothing it out... I'm gonna re-drill a mount for the choke cable so i left the flat part that sticks out... sand blasted it and did some polishing.... keep in mind this is my first attempt at anything like this... but i think it turned out alright.
Offline Kong
« Reply #16 on: February 19, 2011, 05:28:53 AM »
I cut mine off with a cutoff wheel and then took them down a bit farther with a grinding disk, then I took it to a machinist who milled the top flat for a grand total of $15.  Mine will differ from those above in that I'm going to powder coat it black when the bike goes back together.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline MoMo
  • Ride like you're invisible
« Reply #17 on: February 19, 2011, 05:54:33 AM »
It did turn out very well, good work...Larry
